Store integration for iOS doesn't work - 5.5.0f3
9 years 10 months ago #1939 by ertanunver
Hello, I use Unity version 5.5.0f3 and last version of asset. Store integration for iOS doesn't work. I have done all steps correctly. Can you check it?
9 years 10 months ago #1940 by Frank
As you are pointing, the Android Store integration works fine, but the IOS integration is currently not working.
This is a known issue and I already have a task to fix this: trello.com/c/obbsfom3/2-ios-store-integration
Most likely that's what I'm going to focus right after finishing the Plurals support.
If possible, please add your vote to that trello task, That will help me prioritize better the fixes/features that are more useful for you and implement them in that order.
Here is a bit more detail about the IOS Store integration issue and workarounds:
inter-illusion.com/forum/i2-localization...in-itunes-xcode#1281
inter-illusion.com/forum/i2-localization...gration-trouble#1890
One workaround to have it working while I finish implementing a proper fix, is to use the content of the plist file that the plugin generates and manually copy that into the plist file inside XCode. Or just add the languages in the Localization section in XCode.
Sorry for this inconvenience, and I will try adding a fix for this as soon as possible.
9 years 10 months ago #1941 by ertanunver
Thanks for quick response. I can handle it manually.
