Accessing Early Versions
12 years 8 months ago - 12 years 8 months ago #38
Accessing Early Versions was created by Frank
Hi guys,
Thanks to all of you who bought the I2 Localization plugin !
I'm trying to add new features and push versions with fixes as soon as possible. But it could take up to 2 weeks for the AssetStore to review and release new versions.
That's why if you send me your purchase invoice to This email address is being protected from spambots. You need JavaScript enabled to view it. you will receive access to download all versions of the plugin without waiting for them to be in the AssetStore.
You will even get access to the beta and alpha versions where you will find upcoming features that could help your project right away.
Thanks a lot,
Thanks a lot,
Last edit: 12 years 8 months ago by Frank.
12 years 8 months ago #40
by sl
Replied by sl on topic Accessing Early Versions
Hi Frank.
First of all, great thanks for this really useful plugin, you are doing a great job.
While working with the latest 2.0.0 a2 version (according to readme file) I've found several bugs and issues which reduce the functionality of the plugin. Do you have any specific place for bug reports? I can report several ones which I've noticed.
Best regards,
Sergey.
Best regards,
Sergey.
12 years 8 months ago #41
Replied by Frank on topic Accessing Early Versions
Hi Sergey,
Thanks for using the plugin!
I was about to release version 2.0.1 with a few fixes and a couple new features that some users suggested.
If you send me the bugs or suggestions you have I can include those in these release!
You can either send an email to This email address is being protected from spambots. You need JavaScript enabled to view it. or create another post in this forum.
Thanks a lot,
Thanks a lot,
The following user(s) said Thank You: Apiweb
12 years 8 months ago #42
by sl
Hi Frank.
I've just sent you an email with the list of issues and suggestions.
Sergey.
Sergey.
12 years 8 months ago #43
Thanks a lot for reporting those issues.
I just released a new version (2.0.1 f1). that includes fixes for the issues you reported and a few more improvements for making the plugin more intuitive.
9 years 7 months ago #2121
by JOY
Replied by JOY on topic Accessing Early Versions
I'd like to suggest you add the changelog to the beta version by using Drive description for each file. It will help us a lot.
Anh
Anh
Time to create page: 0.211 seconds
