Tutorials are not updated
7 years 11 months ago #3318
by Nalsur
Tutorials are not updated was created by Nalsur
I follow the tutorial (
www.inter-illusion.com/tools/i2-localization
) but there is no more prefab in Ressource folder.
you don't explain how the new "ScriptableObject" has to be used. I'm a newbee, and i need to follow an uptodate tutorial to be able to use your solution.
Please can you how I have to proceed with the "scriptableObject"?
www.inter-illusion.com/tools/i2-localization seems to be out to date because it tells about the former prefab.
thanx
Regards
thanx
Regards
7 years 11 months ago #3320
Replied by Frank on topic Tutorials are not updated
The flow of using the ScriptableObject is the same than using the Prefab. Its just the name what changed (and the folder). Now instead of I2Languages.prefab is I2Languages.asset.
Said that, I have updated the tutorial with the new changes and a few other outdated bits. Most likely will be uploading it tomorrow after I finish cleaning it a bit.
BTW, The new documentation will be replacing this one:
inter-illusion.com/assets/I2Localization...l/HowtoLocalize.html
The following user(s) said Thank You: SweatyChair
7 years 11 months ago #3322
by Nalsur
Replied by Nalsur on topic Tutorials are not updated
Thanx !
I hope you will update quickly. I need it
this morning the updated version was not available yet
Regards,
Regards,
7 years 11 months ago #3323
by Nalsur
Thanx !
Regards,
Regards,
- FootyDirector
7 years 11 months ago #3325
by FootyDirector
Replied by FootyDirector on topic Tutorials are not updated
On Mac using 2018.3.b12 in Assets/I2/Localization I only have Examples and Scripts sub folders, is this correct with the latest version?
Also when clicking on the 'Open I2 Languages.prefab' menu option I get an error :-
Handles.Repaint called outside an editor OnGUI
UnityEditor.HandleUtility:Repaint()
I2.Loc.LocalizationEditor:CallLocalizeAll() (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms.cs:800)
Regards
Regards
7 years 11 months ago #3326
Are you using I2 Localization v2.8.9 or v2.8.10 ?
v2.8.8 and previus ones are not compatible with unity 2018.3 because of its changes to the prefabs workflow.
Time to create page: 0.177 seconds
