Send failed since rewinding of the data stream...
8 years 10 months ago - 8 years 10 months ago #2608
by pete
Send failed since rewinding of the data stream... was created by pete
I just installed the plugin and followed the video to create a goggle drive access.
I pasted the link in the Web Service URL, can validate it, can create new spreadsheet, can access them, can see them, etc.
When I do translate all, I have this error : Send failed since rewinding of the data stream failed.
I don't know if this is linked or not (and I'm not sure I should create another thread), but I can't add term to source from the menu (when I click on the item), I need to click at the bottom of the language source to make it work ...
Error for stream failed:
Also,
If I do a Replace or Merge from Export, it says : Unable to access google.
NullReferenceException: Object reference not set to an instance of an object
I2.Loc.LocalizationEditor.OnGUI_Keys_Languages (System.String Key, I2.Loc.Localize localizeCmp, Boolean IsPrimaryKey) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs:181)
I2.Loc.LocalizationEditor.OnGUI_KeyList_ShowKeyDetails () (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs:40)
I2.Loc.LocalizationEditor.OnGUI_KeysList (Boolean AllowExpandKey, Single Height, Boolean ShowTools) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms.cs:130)
I2.Loc.LocalizationEditor.OnGUI_Main () (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:64)
I2.Loc.LocalizationEditor.OnInspectorGUI () (at Assets/I2/Localization/Scripts/Editor/Inspectors/LanguageSourceInspector.cs:160)
UnityEditor.InspectorWindow.DrawEditor (UnityEditor.Editor editor, Int32 editorIndex, Boolean rebuildOptimizedGUIBlock, System.Boolean& showImportedObjectBarNext, UnityEngine.Rect& importedObjectBarRect) (at C:/buildslave/unity/build/Editor/Mono/Inspector/InspectorWindow.cs:1240)
UnityEditor.DockArea:OnGUI()Error for stream failed:
I2.Loc.LocalizationEditor:ShowMessage(String, MessageType, Boolean) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:215)
I2.Loc.LocalizationEditor:ShowError(String, Boolean) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:200)
I2.Loc.<OnGUI_Keys_Languages>c__AnonStorey1:<>m__0(String, String) (at Assets/I2/Localization/Scripts/Editor/Localization/LocalizationEditor_Terms_Description.cs:255)
I2.Loc.<Translate>c__AnonStorey1:<>m__0(Dictionary`2, String) (at Assets/I2/Localization/Scripts/Google/GoogleTranslation.cs:52)
I2.Loc.<WaitForTranslation>c__Iterator0:MoveNext() (at Assets/I2/Localization/Scripts/Google/GoogleTranslation_Post.cs:108)
I2.Loc.<Start>c__AnonStorey1:<>m__0() (at Assets/I2/Localization/Scripts/Utils/CoroutineManager.cs:39)
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()Also,
Last edit: 8 years 10 months ago by pete.
8 years 10 months ago #2609
Replied by Frank on topic Send failed since rewinding of the data stream...
What version of Unity are you using?
There is was a unity bug in one of the releases (was fixed in later versions and patches), where doing a web POST call where the website does a redirect (like the one Google does), was not properly managed by Unity WWW class. And it gave an error related to the rewinding.
I solve that for the Translate by doing first a POST call and if that failed, fallback to a GET. But I haven't implemented a workaround for that bug in the Export/Import from Spreadsheets.
Please, let me know what Unity version is that so that I could try it there and find a workaround for that as well.
8 years 10 months ago #2610
by pete
Replied by pete on topic Send failed since rewinding of the data stream...
Thanks for the quick answer.
Here are the infos:
I use Unity 5.6.3p1 (personal edition - patched version)
I have the latest version of your plugin (2.8.1f1)
I have a clean project.
About the "Unable to access google", I still can see that my sheet is updated, but I still have the error popping in Unity ...
Here are the infos:
8 years 10 months ago #2611
I found the issue for the first problem, what happens its that on the last release I added support for autodetecting the term type based on the context (Font, Sprite, Text, etc).
The code that does that, is reused for both the Language Source and the Localize component, but I didn't test it in the language Source, just the Localize component. Sorry!
To fix the issue, just add
localizeCmp!=null &&
to the if at Assets\I2\Localization\Scripts\Editor\Localization\LocalizationEditor_Terms_Description.cs line 181
It should look like:
Will be adding that fix to 2.8.2a2 later today, and upload it to the beta folder.
That's the expected behavior (well, the expected result considering the Unity bug
What happens its that on Export, I send all the data to google using a POST call.
The Google Webservice reads the data correctly and updates the spreadsheet. But when it finishes, Google finalizes the POST call and sends back to unity an empty result. But it does that using a redirect to that empty data.
When unity receives that, it sees the redirect url, but that unity version has a bug that fails when there is a redirect. So, you get the error message.
I'm not doing anything with the result, I DONT WANT THE RESULT! haha, but still the www fails and unity complains about that.
I'm going to see if I can make an override in my code, to not report the unity error in that case if its a redirect error, given that I'm not doing anything with the returning data.
Will include the fix in 2.8.2a2 as well.
var termType = eTermType.Text;
if (localizeCmp!=null && localizeCmp.mLocalizeTarget != null)
termType = IsPrimaryKey ? localizeCmp.mLocalizeTarget.GetPrimaryTermType(localizeCmp)
: localizeCmp.mLocalizeTarget.GetSecondaryTermType(localizeCmp);
}Will be adding that fix to 2.8.2a2 later today, and upload it to the beta folder.
8 years 10 months ago #2612
by pete
That was fast. I don't mind bugs (well, not when you want to ship), it happens, we just need to make sure they don't stay in the way for too long.
I'll wait for the beta version
I'm not in a rush anyway, just exploring the plugin.
So just to confirm with you as I receive two kind of message log with the same issue:
I get this message in the regular (Debug)Log: Send failed since rewinding of the data stream failed... UnityEngine.Debug:Log(Object) ... when I want to Export something (which is what you talk about).
But I receive it as a (Debug)LogError when I try to use Translate All.
Both are related?
Thanks again.
Both are related?
Thanks again.
8 years 10 months ago #2618
Both errors are related (happen through different code paths, but the same issue).
Here is a fix: inter-illusion.com/forum/i2-localization...data-stream-fai#2617
I also uploaded v2.8.2a2 to the beta folder.
The following user(s) said Thank You: pete
Time to create page: 0.176 seconds
