Exporting I2 problem with newline
9 years 4 months ago #2207 by Frank
I checked your prefab and the problem is that some of the texts contains TABs (\t) before the line breaks (\n).
To correctly export this to csv, you should change the separator to "Comma (,)" instead of "Tab (\t)" in the Local Spreadsheet Export settings.
CSV are better handled by excel when its separated by commas.
When exporting with those settings you get the correct result in excel:
9 years 4 months ago #2208 by fabiobp
Oh, I didn't see that. you made my day.
9 years 4 months ago #2209 by fabiobp
Frank, I changed it to comma (,), but I still get the same problem. What's your version of Excel? I'm sending a exported file with comma attached.
File Attachment:
File Name: SFLocaliza...nhol.csv
File Size:26 KB
9 years 4 months ago #2210 by Frank
I'm using Excel 2013.
I tried opening the csv you just sent me and it opens correctly.
One thing that I noticed, is that excel automatically tries to detect the type of csv file, and some times it select comma separated, other times it thinks its tab separated or even fixed width.
That's most likely your issue. Excel its not importing the csv with the correct settings.
To solve that, you should change the excel settings by closing excel, and opening it again, then click in File / Open and change the settings that popup to "Delimited" and Comma separated (but not tab). as shown in the next image:
Another way to force this is by using Import Data instead of Open the csv file.
Just click in Data \ From Text \ Import and change the settings there.
Sorry for all this issues, but that's the bad thing about csv been such an open/customizable format!
The following user(s) said Thank You: fabiobp
9 years 4 months ago #2211 by fabiobp
Hi Frank, i'm doing exactly that. I've tried to import by opening and by importing. I'm actually experienced in Excel, but this is new to me. It might have some excel property and not I2Localization problem. I'd appreciate if you could send me the file you exported in .xlsx format.
Thanks for your support!
9 years 4 months ago #2212 by Frank
Attached is the xlsl version of the csv file you sent me.
I just opened that csv file in excel 2013 and exported it.
Could you try opening the csv file in excel in another computer to see if there is a problem with local settings of your excel ?
File Attachment:
File Name: SFLocaliza...nhol.zip
File Size:22 KB
Time to create page: 0.189 seconds
