Exporting I2 problem with newline
9 years 5 months ago #2213 by fabiobp
Hi Frank, I tried several PCs and MAC all the same. I also tried to change character set on import but nothing changes.
I converted your file to CVS and re-imported, it opens right.
I opened your file on notepad++, and saw that where it doesn't break line correctly it have a LF character. An there it really ends the text and change to another line, it has a CR+LF character.
I exported the I2 file in CSV and opened it on notepad++, the file only contain LF character on both case.
Any idea?
9 years 5 months ago #2214 by fabiobp
I'm exporting as utf-8.
9 years 5 months ago #2219 by nzgreg
hey fabiobp and Frank,
we also have problems exporting CSV data and importing into Excel. It's a known problem importing csv data with cells that contain linefeeds - there are lots of frustrated posts on stack overflow and other sites that complain about it.
In our tests the data that Excel could not load works fine with Google Sheets.
cheers,
// greg
The following user(s) said Thank You: bazz_boyy
Time to create page: 0.122 seconds
