namespace name `TextMeshProFont' does not exist
10 years 10 months ago #1201
by ababab5
namespace name `TextMeshProFont' does not exist was created by ababab5
I have this errors:
Assets/I2/Localization/Scripts/Targets/LocalizeTextMeshPro.cs(39,31): error CS0234: The type or namespace name `TextMeshProFont' does not exist in the namespace `TMPro'. Are you missing an assembly reference?
Assets/I2/Localization/Scripts/Targets/LocalizeTextMeshPro.cs(80,31): error CS0234: The type or namespace name `TextMeshProFont' does not exist in the namespace `TMPro'. Are you missing an assembly reference?
How can I solve it ?
I use your last I2 version available on the asset store, and the last TextMeshPro too.
Thanks.
Best regards,
AB
I have this errors:
Thanks.
Best regards,
AB
10 years 10 months ago #1202
Replied by Frank on topic namespace name `TextMeshProFont' does not exist
The latest version of TextMeshPro renamed a few classes, thats why older versions of I2L fail to compile.
I created a new version (I2L 2.6.4 a1) that fixes the issue by spliting the TextMeshPro support into TextMeshPro and TextMeshPro_Pre53.
I uploaded that version to the AssetStore, but it will take a few days before it gets approved. In the meantime you can download it from the beta folder.
More details here: inter-illusion.com/forum/i2-localization...hpro-0-1-52-beta-3-1
The following user(s) said Thank You: ababab5
10 years 10 months ago #1203
by roolza
Replied by roolza on topic namespace name `TextMeshProFont' does not exist
I am having the same problem. Where is the beta folder?
10 years 10 months ago #1204
Just send me an email to This email address is being protected from spambots. You need JavaScript enabled to view it. with your invoice number and I will enable access for you to the beta folder.
Time to create page: 0.197 seconds
