Using spreadsheet to remotely change a password?
11 years 1 month ago #1024
by jimmyt3d
Using spreadsheet to remotely change a password? was created by jimmyt3d
Currently I have a basic password system on my game in the form of the following script -
However what would be really good, would be if I could remotely change the password from the Google spreadsheet, so that the script looks to the plugin/spreadsheet rather than a baked in password like it is at the moment.
Would it be possible to modify this script to achieve this?
Many thanks
#pragma strict
var password : String = "";
function OnGUI () {
password = GUI.PasswordField (Rect (Screen.width/2, Screen.height / 1.95, 256, 32), password, "*" [0], 25);
if (password == "password123")
Application.LoadLevel("Level_1");
}However what would be really good, would be if I could remotely change the password from the Google spreadsheet, so that the script looks to the plugin/spreadsheet rather than a baked in password like it is at the moment.
Many thanks
11 years 1 month ago #1025
Replied by Frank on topic Using spreadsheet to remotely change a password?
Yes, you can store game data in your spreadsheet and it will be downloaded.
You can create a new term (or row in the spreadsheet) named "GamePassword" or anything that fits. And for every language, set the password as its translation.
Then, in the game, execute
password = I2.Loc.ScriptLocalization.Get("GamePassword", false);Hope that helps,
11 years 1 month ago #1028
by jimmyt3d
Replied by jimmyt3d on topic Using spreadsheet to remotely change a password?
Thanks for your help, I am almost there, I have written the following script and attached it to the password input field.
Without your line, the password box accepts whatever I put in the (incomingPassword == "???") field as the password and correctly loads the level.
If I add your line in, I get the error - "The name 'password' does not exist in the current context", so I changed 'password' to 'incomingPassword' and the error disappears and the game loads, however nothing happens when I put the password in.
I assume I am missing something to connect the password in the plugin to the 'incomingPassword' field?
Many thanks
public class PasswordInput2 : MonoBehaviour {
public void PassWordCheck(string incomingPassword)
incomingPassword = I2.Loc.ScriptLocalization.Get("GamePassword", false);
if (incomingPassword == "GamePassword")
}Without your line, the password box accepts whatever I put in the (incomingPassword == "???") field as the password and correctly loads the level.
Many thanks
11 years 1 month ago #1029
I think you should compare the incoming password with the one you get from I2.
var RealPassword = I2.Loc.ScriptLocalization.Get("GamePassword", false);
if (incomingPassword == RealPassword)
}Hope that helps,
The following user(s) said Thank You: jimmyt3d
11 years 1 month ago #1031
by jimmyt3d
That works perfectly, thanks for your help!
8 years 11 months ago - 8 years 11 months ago #2628
by jimmyt3d
I have just updated Unity to 5.6.4 (was previously on 5.3.5) and I2Loc to v2.8.1f1 (was previously on v2.7.0f1) and am now getting the following error for this script -
Assets/Scripts/PasswordInput2.cs(11,29): error CS0234: The type or namespace name `ScriptLocalization' does not exist in the namespace `I2.Loc'. Are you missing an assembly reference?
Has something changed in the latest version to cause this?
My full script which has always worked prior to this update, is as follows -
Many thanks
using UnityEngine;
using System.Collections;
public GameObject myObject;
public GameObject myObject2;
var RealPassword = I2.Loc.ScriptLocalization.Get("Maps_Password", false);
myObject.SetActive(false);
myObject2.SetActive(true);
else
myObject.SetActive(true);
myObject2.SetActive(false);
}Many thanks
Last edit: 8 years 11 months ago by jimmyt3d.
