Using spreadsheet to remotely change a password?
8 years 11 months ago #2634 by Frank
As of a couple versions ago, the ScriptLocalization file is no longer included with the plugin, it is auto generated if you use the Bake Term tools.
Previously the ScriptLocalization.Get was just a handy way of calling LocalizationManager.GetTranslation(...) while having all your localization access inside the same script.
Now, the way to go is to call LocalizationManager.GetTranslation directly, that's faster and if you are not using ScriptLocalization.cs then its one script less to compile :-)
Time to create page: 0.163 seconds
