Reference rewriter: Error
11 years 3 months ago - 11 years 3 months ago #858
by regaaa
Reference rewriter: Error was created by regaaa
Hi there,
first of all: Awesome plugin! It just works. It saved me a lot of time and all but I have a problem:
Reference rewriter: Error: method `System.String System.Globalization.TextInfo::ToTitleCase(System.String)` doesn't exist in target framework. It is referenced from Assembly-CSharp.dll at System.String I2.Loc.GoogleTranslation::ParseTranslationResult(System.String,System.String).
PostProcessWinRT:RunReferenceRewriter() (at C:/buildslave/unity/build/PlatformDependent/WinRT/SharedSources/CSharp/PostProcessWinRT.cs:503)
PostProcessWinRT:Process() (at C:/buildslave/unity/build/PlatformDependent/WinRT/SharedSources/CSharp/PostProcessWinRT.cs:98)
UnityEditor.HostView:OnGUI()
This error appears If I try to build my game, to be more precise, after build process is over. Well, the game gets built, but this error makes me nervous.
The game is for Windows Phone (in case it matters).
Last edit: 11 years 3 months ago by regaaa.
11 years 3 months ago - 11 years 3 months ago #859
Replied by Frank on topic Reference rewriter: Error
As soon as I get back to my computer I will try it and give you a fix.
The ToTitleCase method is been used to make the translation returned by google match the case of the original sentence:
So that "Where Is The Tutorial" gets translated to "Donde Esta El Tutorial" instead of "donde esta el tutorial".
That will only affect you if you are using dynamic translation in the game (translating chat messages or other user inputs). As translation will work when in the Editor.
I will check exactly whats the issue and let you know.
Last edit: 11 years 3 months ago by Frank.
11 years 3 months ago #861
by regaaa
Replied by regaaa on topic Reference rewriter: Error
So If I do not use this feature, the created app package will be ok, right? This is more a kind of a runtime error, right? But why then do I get this error during building my game?
11 years 3 months ago #862
Most likely it will fail building for Metro as that method is not available there.
Metro uses a different .Net Framework, so when building the game for that platform, that method will not be found and it will fail building.
If you are not using dynamic translation, you could comment out the line of that error and it will work.
But as soon as I get back I will write an extension script to include that method on Metro and send it to you
11 years 3 months ago - 11 years 3 months ago #865
by regaaa
Ok, I'm waiting then. But in the meantime I've also commented out the faulty lines. Thank you.
EDIT: I've read your answere again. I do not build for metro. Is there something wrong in my setup, then?
11 years 3 months ago #868
Attached you can find a fix for the missing method.
Can you try it and let me know if that fixes the issue for you.
I was assuming is for the windows platform as its executing the PostProcessWinRT.
Can you tell me which unity version you are using and for what platform you are having the error. That way I can adjust the correct platform defines.
Time to create page: 0.204 seconds
