Reference rewriter: Error
11 years 1 week ago #1007 by actraiser
Replied by actraiser on topic Reference rewriter: Error
I just encountered the same problem building for WP8.0 on Unity 5.2.1p2
Error: method `System.String System.Globalization.TextInfo::ToTitleCase(System.String)` doesn't exist in target framework. It is referenced from Assembly-CSharp.dll at System.String I2.Loc.GoogleTranslation::TitleCase(System.String).
I tried overwriting GoogleTranslation.cs with your attached file but it did not change the output. Any other ideas?
Best
–act
11 years 1 week ago #1008 by Frank
Replied by Frank on topic Reference rewriter: Error
There may be an issue with the NETFX_CORE in the latest patch. I will try deploying to wp8 and verify that.
Nonetheless, a quick workaround to fix the issue is to replace line 125 in GoogleTranslation.cs file
from
			#if NETFX_CORE
to
			#if true
That will remove the ToTileCase function and will use a custom version instead.
As soon as I get back I will run the test and add the official fix to 2.7.0b2
11 years 1 week ago - 11 years 1 week ago #1009 by actraiser
Hello Frank,
thank you, that was nearly the solution. The code between the #if/#endif block does not work because strings are strictly immutable, so Visual Studio throws an error. I modified the function to use Stringbuilder instead and this worked - also compilation completes successfully. Here is my workaround for the TitleCase-method for anyone needing that fix right away.
public static string TitleCase(string s)
    StringBuilder sb = new StringBuilder();
    if (string.IsNullOrEmpty(s))
        return string.Empty;
    } else{
        sb.Append(s);
    #if true
    sb[0] = char.ToUpper(sb[0]);
    for (int i = 1, imax=sb.Length; i<imax; ++i)
        if (char.IsWhiteSpace(sb[i - 1]))
            sb[i] = char.ToUpper(sb[i]);
        else
            sb[i] = char.ToLower(sb[i]);
    return sb.ToString();
    #else
    return System.Globalization.CultureInfo.CurrentCulture.TextInfo.ToTitleCase(sb);
    #endif
-act
Last edit: 11 years 1 week ago by actraiser.
11 years 1 week ago #1014 by Frank
Thanks for checking that up.
I will add a similar fix to the next release!
Time to create page: 0.246 seconds
