Applying global parameters through code
5 years 8 months ago #4216 by Graham
I see an old example here http://inter-illusion.com/forum/i2-localization/748-parameters-isn-t-change-when-i-apply-text-by-code#1973http://inter-illusion.com/forum/i2-localization/748-parameters-isn-t-change-when-i-apply-text-by-code#1973 but it seems outdated. Could I get an up to date example of translating a text and applying global parameters at the same time through code?
5 years 8 months ago #4217 by Graham
I've tried: (where the termKey = The best player was {[WINNER}]!)
string dialogue = LocalizationManager.GetTranslation(termKey);
LocalizationManager.ApplyLocalizationParams(ref dialogue, true);
But it doesn't do anything, I've added the GlobalParametersExample component to the scene.
5 years 8 months ago #4223 by Frank
There seems to be a typo in the tags: instead of {[ }] use {[ ]} (see the order of ] and })
Also, you can avoid using ApplyLocalizationParams by doing:
string dialogue = LocalizationManager.GetTranslation(termKey, applyParameters:true);
Time to create page: 0.181 seconds
