Parameters isn't change when I apply text by code
9 years 9 months ago - 9 years 9 months ago #1971 by Philomat
I apply text to UI label by code
using I2.Loc;
using UnityEngine;
using UnityEngine.UI;
void Start()
  string desc = ScriptLocalization.Get("_missionReachScore");
  GetComponent<Text>().text= "" + desc;
key "_missionReachScore" value is
Win any level with more than {[SCORE]} score
In your examples Parameters changing by attaching Localize component to label, can I do same in my script without Localize component?
Last edit: 9 years 9 months ago by Philomat.
9 years 9 months ago #1973 by Frank
ScriptLocalization.Get doesn't call the parameters directly, so that you could do some further processing (changing/adding parameters before replacing them).
You need to call
LocalizationManager.ApplyLocalizationParams(ref desc, null);
to replace the GLOBAL parameters in desc.
You can register global parameters using a script similar to
Assets\I2\Localization\Examples\Common\Scripts\GlobalParametersExample.cs
Just add that to any of the objects in your first scene.
That way, the code becomes:
using I2.Loc;
using UnityEngine;
void Start()
using UnityEngine;
using System.Collections;
namespace I2.Loc
    public class GlobalParametersExample : RegisterGlobalParameters
		public override string GetParameterValue( string ParamName )
            if (ParamName == "WINNER")
                return "Javier";            // For your game, get this value from your Game Manager
            if (ParamName == "NUM PLAYERS")
                return 5.ToString();
            return null;
The following user(s) said Thank You: Philomat
9 years 9 months ago #1974 by Frank
BTW, I just added another version of ScriptLocalization.Get that automatically applies the parameters:
public static string Get(string Term, bool FixForRTL, int maxLineLengthForRTL, bool ignoreNumbers, bool applyParameters, GameObject localParametersRoot)
and you can use it like this:
string desc = ScriptLocalization.Get("_missionReachScore", LocalizationManager.IsRight2Left, 0, false, true, null);
That will be available in the new version (2.6.10a1)
Time to create page: 0.176 seconds
