- Forum
- Plugins
- I2 Localization
- Apparent bug in LocalizeTarget_UnityStandard_GUITexture.cs (2019.3.4f1)
- seancronin
6 years 7 months ago #4073
by seancronin
Updating to Unity 2019.3.4f1 seems to have broken several lines in LocalizeTarget_UnityStandard_GUITexture.cs. The following build-breaking errors are appearing for me:
Assets\I2\Localization\Scripts\Targets\LocalizeTarget_UnityStandard_GUIText.cs(9,72): error CS0619: 'GUIText' is obsolete: 'GUIText has been removed. Use UI.Text instead.'
Assets\I2\Localization\Scripts\Targets\LocalizeTarget_UnityStandard_GUIText.cs(9,18): error CS0311: The type 'UnityEngine.GUIText' cannot be used as type parameter 'T' in the generic type or method 'LocalizeTarget<T>'. There is no implicit reference conversion from 'UnityEngine.GUIText' to 'UnityEngine.Object'.
Assets\I2\Localization\Scripts\Targets\LocalizeTarget_UnityStandard_GUITexture.cs(9,75): error CS0619: 'GUITexture' is obsolete: 'GUITexture has been removed. Use UI.Image instead.'
Assets\I2\Localization\Scripts\Targets\LocalizeTarget_UnityStandard_GUITexture.cs(9,18): error CS0311: The type 'UnityEngine.GUITexture' cannot be used as type parameter 'T' in the generic type or method 'LocalizeTarget<T>'. There is no implicit reference conversion from 'UnityEngine.GUITexture' to 'UnityEngine.Object'.
Is this a known issue, and if so, is there a fix in the works?
6 years 7 months ago #4074
Replied by Frank on topic Apparent bug in LocalizeTarget_UnityStandard_GUITexture.cs (2019.3.4f1)
See my reply here:
inter-illusion.com/forum/i2-localization...-2019-3?start=6#3999
That should fix the problem.
See my reply here:
- Forum
- Plugins
- I2 Localization
