Adding randomness
9 years 10 months ago #1883 by WillyWonka
Adding randomness was created by WillyWonka
I've been able to setup an animation so that letters animate into position sequentially with a delay, but is it possible to randomly select which letters animate so that it's out of order?
Is it possible to adjust animations on the fly via code?
9 years 10 months ago - 9 years 10 months ago #1885 by Frank
Replied by Frank on topic Adding randomness
Hi
Each sequence can have random values (position, scale, etc), but there is no setting for random starting, just sequential with customizable ease curve.
With the feedbacks I have gathered about the Animation system, I'm about to tweak it to make it easier to work with, so while I do that I will make sure to add a Random setting for the ease curve as well.
Don't hesitate in letting me know If you find anything else missing or have a suggestion on how to make it easier for you!
yes, you have full access to every parameter.
Basically, you can do play and modify values this way:
            var se = GetComponent<SmartEdge>();
            se.StopAllAnimations();
            var anim = se.PlayAnim("Pulse");
            var sequence = anim._Sequences[0] as SE_AnimSequenceType_Position;
            sequence._To = new Vector3(10,0,0);
Hope that helps
Last edit: 9 years 10 months ago by Frank.
