GC problem on LanguageSource.FindAsset
8 years 9 months ago #2696 by yuewah
LanguageSource.FindAsset use Object[] Assets, that searching using UnityEngine.Object.name
however, it alloc GC, especially if there are many Assets, it alloc GC very fast.
Is it possible to use Dictionary<string, Object> ?
8 years 9 months ago #2697 by Frank
Thanks a lot for pointing this out. I verified that just asking for the GameObject.name causes a GC!
I will be releasing a workaround for this in the next beta.
8 years 9 months ago #2698 by yuewah
Btw, the use of Regex is also a problem too
Time to create page: 0.192 seconds
