Access localized strings from script?
8 years 9 months ago #2693 by jdev
Is it possible to access localized strings from a script?
8 years 9 months ago #2694 by Frank
Do you mean:
- Get the translation of a Term from code?
use: LocalizationManager.GetTranslation( "Term 1" );
as long as Term 1 is in your I2Languages.prefab, this will return the translation to the current language.
- Get the internal translation data to all languages
var termData = LocalizationManager.GetTermData("Term 1");
That contains an array of languages with the translation to each of the languages.
- Use the LocalizedlString class?
Assets\I2\Localization\Examples\Common\Scripts\Example_LocalizedString.cs
8 years 9 months ago #2695 by jdev
Ah, thank you!
Time to create page: 0.127 seconds
