Auto update frequecy from code
8 years 9 months ago - 8 years 9 months ago #2687 by giorgiodeluca
hi,
how can set Auto update frequecy from code?
is it possible to force the update?
  if I release a new version of my app who does the update of the app (not new installation) does not have the updated translation, I would like to force the update of the terms from code. How can I do?
thanks
Last edit: 8 years 9 months ago by giorgiodeluca.
8 years 9 months ago - 8 years 9 months ago #2691 by Frank
If you want to start the update process manually, just call:
I2.Loc.LocalizationManager.Sources[0].Import_Google(true);
That will execute a coroutine with the update and then update the UI when it finishes.
Last edit: 8 years 9 months ago by Frank.
The following user(s) said Thank You: giorgiodeluca
8 years 9 months ago #2699 by giorgiodeluca
thanks
