Get translation/asset with specified language
- OrangyTang
8 years 10 months ago #2639
by OrangyTang
Get translation/asset with specified language was created by OrangyTang
Hello!
I'd like to lookup an ID to a translation and a translated asset, but with a language I specify. eg. something like:
LocalizationManager.TryGetTermTranslation(id, out translatedId, "LanguageID");
Is this possible? I could only find this post from a while back, but I can't see the changes in the source I have locally.
www.inter-illusion.com/forum/i2-localiza...age-parameter-to-get
Thanks.
Thanks.
8 years 10 months ago #2642
Replied by Frank on topic Get translation/asset with specified language
In the latest release, the GetTranslation and TryGetTranslation functions have a parameter to override the language:
To call it, you just need to pass all parameters like in:
or simply add it as a named parameter
class LocalizationManager
public static string GetTranslation(string Term, bool FixForRTL = true, int maxLineLengthForRTL = 0, bool ignoreRTLnumbers = true, bool applyParameters = false, GameObject localParametersRoot = null, string overrideLanguage = null)
public static bool TryGetTranslation(string Term, out string Translation, bool FixForRTL = true, int maxLineLengthForRTL = 0, bool ignoreRTLnumbers = true, bool applyParameters = false, GameObject localParametersRoot = null, string overrideLanguage = null)
}To call it, you just need to pass all parameters like in:
LocalizationManager.TryGetTranslation(id, out translatedid, true, 0, true, false, null, "Spanish");or simply add it as a named parameter
LocalizationManager.TryGetTranslation(id, out translatedid, overrideLanguage:"Spanish");Hope that helps,
