Arabic fix when language is LTR
8 years 11 months ago #2629
by arisbrink
Arabic fix when language is LTR was created by arisbrink
I have come upon an issue where we want dynamic texts to be in Arabic and in English.
How can we make sure that that the Arabic texts are displayed correctly even if the selected language is English?
8 years 11 months ago #2630
by arisbrink
Replied by arisbrink on topic Arabic fix when language is LTR
What we do now is this:
internal static bool HasArabicCharacters(string text)
Regex regex = new Regex("[\u0600-\u06ff]");
return regex.IsMatch(text);
We check in our loop if the string contains Arabic characters and depending on the outcome we ApplyArabicFix or not.
LocalizationManager.ApplyRTLfix(string, 0, true);
If there is a cleaner method, please share.
8 years 11 months ago #2635
Replied by Frank on topic Arabic fix when language is LTR
I guess that what you are doing is the easiest way of doing it.
Alternatively, you could just call LocalizationManager.ApplyRTLfix to the entire string even if it doesn't have Arabic characters, that call will skip the regular characters. Just be sure to set to ignore numbers.
The issue with calling ApplyRTLfix all the time, is that when using tags (e.g. [color], [0xffffff], etc) the RTLfix tries to reorder the tags to make sense when rendering from right to left.
The other way (more reliable), is to add a tag <rtl> </rtl> to encapsulate your Arabic strings. Then, in the code that uses the translation (either your own script or a localization callback), see if you have a tag and apply rtl only to the inside, then remove the tags.
That way, its the safest, as it will deal correctly with other tag types, numbers, etc. But its a bit more involved.
Time to create page: 0.124 seconds
