problem with InputField
- Behdadsoft
8 years 11 months ago #2598
by Behdadsoft
problem with InputField was created by Behdadsoft
Hi.
I want when i try to write my Arabic text into InputField in game mode, I2 Localization fix it to correct text. but when i use below code it don't work and only show one character in InputField.
how can do it?
Thanks.
using System;
using System.Collections;
using UnityEngine;
using UnityEngine.UI;
using I2.Loc;
public class Input_feild : MonoBehaviour
public InputField input;
void OnGUI()
input.text = LocalizationManager.ApplyRTLfix(input[0].text);
}how can do it?
Thanks.
- Behdadsoft
8 years 11 months ago #2602
by Behdadsoft
Replied by Behdadsoft on topic problem with InputField
I want know I2 Localization can fix InputField text during typing?
8 years 11 months ago #2604
Replied by Frank on topic problem with InputField
Sorry for the delay in answering, this last days I have been traveling and unable to connect as often as I would have liked.
Unfortunately, the code to fix the InputFields is a bit more complicated:
- FixRTL can introduce/remove characters, so the cursor position needs to be adjusted accordingly.
- RTL is written from right to left, so the text needs to be reversed and cursor movement should be reversed as well.
- There is no callback in the InputField happening between the OnValueChanged and when the text is set in the TextComponent, (even the password masking happens in the same method), so the code needs to delay changing the text until after the InputField finishes updating its values.
I started doing some tests on making a component to fix InputFields when the current language is RTL. Will let you know as soon as its functional enough.
- Behdadsoft
8 years 11 months ago #2605
by Behdadsoft
Hi.
Thanks for reply.
I found a free Persian package that can fix RTL text into InputField directly and work very well.
UPersian: Unity Game Engine RTL Support
Thanks for reply.
Time to create page: 0.133 seconds
