Dollar symbols $ not showing
8 years 11 months ago #2583
by Doobly
Dollar symbols $ not showing was created by Doobly
When I run my game on a device it does not show the dollar symbols that I've applied for each language. These symbols are removed when the text are displayed: $ ₽ € ₩ ¥
It works fine in the editor just not on mobile. I haven't tried webgl yet. Anything special I should be doing?
8 years 11 months ago #2584
Replied by Frank on topic Dollar symbols $ not showing
I tried running a test scene with a text having those characters and its displaying correctly. Both in the editor and in the device.
Can you give me more details about this, so that I could reproduce it.
- What version of unity are you using?
- What version of I2 Localization.
- Could this issue be related to having Google Live Synchronization enabled and the Google Spreadsheet is not up-to-date?
- Are you using Unity UI, TextMesh Pro or NGUI?
- If you are using a custom font, are those characters defined there?
- If you update your text, the version in the device updates correctly (but with the missing chars you mentioned)?
8 years 11 months ago #2585
by Doobly
Replied by Doobly on topic Dollar symbols $ not showing
5.6.4p2
2.8.0
Google Live Sync is turned on and all of the values are up to date
Unity UI with Rich Text on and Fit To size
Yes, very common font
Not even with updating it, it removes the characters on mobile devices by default
I've attached some screen shots.
5.6.4p2
2.8.0
8 years 11 months ago #2586
by Doobly
Attaching some screenshots of the game.
The one with the dollar symbol is in the editor. The other on iPhone 6 (problem also happens on android)
