Maximum Categories
9 years 1 week ago #2557 by 71M
Maximum Categories was created by 71M
Is it possible to have more than 32 categories?
Looking at the code, I don't see how that's possible.
Cheers,
Tim
9 years 1 week ago #2558 by Frank
Replied by Frank on topic Maximum Categories
I2 Localization doesn't constrain the number of categories you have. Categories are just extracted from the term's name (e.g. Tutorial/Title). So, there can be as many categories as terms.
Said that, the Term's list in the Language Source inspector, uses a unity GUI.MaskField which only allows 32bits. That breaks the filtering of terms in that list as soon as you have more than 32 categories.
However, if you filter by "everything", you can still have more than 32 categories. And ALL categories are shown as a popup tree when selecting terms in the Localize inspector. You just wont be able to filter in the Term's list, even thought all of the term will show the correct category tag.
I have a task to fix this issue with the MaskField (i.e. use my own custom Mask selection), but it seems that there is always a feature that takes priority. Now that Plurals are done, and I'm finishing the Extended Input Specialization, I will finally get to those smaller fixes!
Please, give your vote here to allow me prioritize it better:
trello.com/c/V3x0W7LP/8-allow-editing-more-than-32-categories
The following user(s) said Thank You: 71M
9 years 1 week ago #2560 by 71M
Replied by 71M on topic Maximum Categories
Thank you for the quick response!
I'll bear that in mind when working with a large number of categories.
8 years 8 months ago #2784 by 71M
We started hitting the 32 category limit so I went ahead and modified the term filter code, might be useful to others.
void OnGUI_SelectedCategories()
	if ( mParsedCategories.Count == 0 )
		return;
	if ( GUILayout.Button( new GUIContent( "Filter" ), "toolbarbutton" ) )
		var menu = new GenericMenu();
		menu.AddItem( new GUIContent( "Everything" ), false, () =>
			mSelectedCategories.Clear();
			mSelectedCategories.AddRange( mParsedCategories );
			ScheduleUpdateTermsToShowInList();
		menu.AddItem( new GUIContent( "Nothing" ), false, () =>
		foreach ( var category in mParsedCategories )
			menu.AddItem( new GUIContent( category ), mSelectedCategories.Contains( category ), () =>
				if ( mSelectedCategories.Contains( category ) )
					mSelectedCategories.Remove( category );
				else
					mSelectedCategories.Add( category );
		menu.ShowAsContext();
8 years 8 months ago #2786 by Frank
Thanks a lot for looking into this!
I like your approach a lot, will add it to the next release!
