Localize on Awake is now not working (v2.8.0b6)
9 years 4 weeks ago #2496 by RoKo0
Localize on Awake is now not working in the .exe file.
(but it is working in the editor)
9 years 4 weeks ago #2497 by RoKo0
I tryed to debug the standalone build file:
public void OnLocalize( bool Force = false )
if (!HasTargetCache() && !FindTarget())
return;
the programm exits here
9 years 4 weeks ago #2498 by RoKo0
And here is what I have read in the unity's documentation:
"Methods marked [RuntimeInitializeOnLoadMethod] are invoked after the game has been loaded. This is after the Awake method has been invoked."
9 years 4 weeks ago #2499 by RoKo0
My fix of Localize.cs:
        public static bool firstStart = false;
        void Awake()
            if (!firstStart)
                LocalizeTarget_UnityUI_Image.AutoRegister();
                LocalizeTarget_UnityUI_RawImage.AutoRegister();
                LocalizeTarget_UnityUI_Text.AutoRegister();
                firstStart = true;
			FindTarget();
			if (LocalizeOnAwake)
				OnLocalize();
9 years 3 weeks ago #2506 by Frank
Thanks for reporting this issue.
This was introduced in the latest version as I'm trying to decouple the Targets from the actual Localization (to allow more targets to be added without modifying the main code). That's why now all the targets now autoRegister themselves.
You are right about the incorrect call order!
I modified the code now to make the AutoRegister method be called before any Awake function.
What I did was to change the [RuntimeInitializeOnLoadMethod] lines by
[RuntimeInitializeOnLoadMethod(RuntimeInitializeLoadType.BeforeSceneLoad)]
That way, they are executed before any object is loaded/initialized.
This change is now available in 2.8.1a1,
Time to create page: 0.208 seconds
