No Localized, No worked
12 years 1 month ago #202
by Livealot
No Localized, No worked was created by Livealot
Brand new, so maybe missed something in setup, but every time I try the tool "Select No Localized Labels" it selects ALL labels whether there is a i2 localize component attached or not. Does this tool just look for the native NGUI localize component?
12 years 1 month ago #208
Replied by Frank on topic No Localized, No worked
The Select No Localized Labels tools only works with NGUI labels and it has some bugs in it.
I'm currently redoing the tools sections to merge some of the tools and rearrange the editor to make it more intuitive.
Thats high on my priority list (right after finishing the Google Spreadsheets updates
The following user(s) said Thank You: Livealot
Time to create page: 0.174 seconds
