Dynamic translation problem
9 years 1 month ago #2446
by Smartin
Dynamic translation problem was created by Smartin
I'm trying to use GoogleTranslation.Translate on some text that's dynamic. No errors are returned but the following is the translation:
<!DOCTYPE html><html><head><link rel="shortcut icon" href="//ssl.gstatic.com/docs/script/images/favicon.ico"><title>Error</title><style type="text/css">body {background-color: #fff; margin: 0; padding: 0;}.errorMessage {font-family: Arial,sans-serif; font-size: 12pt; font-weight: bold; line-height: 150%; padding-top: 25px;}</style></head><body style="margin:20px"><div><img alt="Google Apps Script" src="//ssl.gstatic.com/docs/script/images/logo.png"></div><div style="text-align:center;font-family:monospace;margin:50px auto 0;max-width:600px">Invalid argument: target (line 33, file "Translate", project "Copy of I2GoogleWebServiceV4")</div></body></html>
Is there something I didn't setup correctly? Thanks so much!
-Steve
-Steve
9 years 1 month ago #2447
Replied by Frank on topic Dynamic translation problem
The problem seems to be that google is not recognizing the language into which you are trying to translate.
If you are translating a term in a LanguageSource, double check that all of the languages have the correct language code (e.g. "en" or "en-US")
If you are using the runtime translation, then you need to specify a correct language code or set "auto" for the original language.
Also, could I ask you into which languages you are localizing. (and what variants if any (e.g. en-CA, es-MX), etc) If its a non common language, I could try it on my side and spot any error.
9 years 1 month ago #2448
by Smartin
Replied by Smartin on topic Dynamic translation problem
Oh, I see... that helps! Was able to find the problem.
I was using:
I2.Loc.GoogleTranslation.Translate(name, "auto",I2.Loc.LocalizationManager.CurrentLanguage, QuestNameTranslation);
When I should've been using...
I2.Loc.GoogleTranslation.Translate(name, "auto",I2.Loc.LocalizationManager.CurrentLanguageCode, QuestNameTranslation);
I was using:
Time to create page: 0.150 seconds
