Hard Crash JNI DETECTED ERROR IN APPLICATION
9 years 2 months ago #2421
by JasonV2G
Hard Crash JNI DETECTED ERROR IN APPLICATION was created by JasonV2G
Hello, I'm having an issue with I2 Localization.
We updated to 2017.1, and then to p4 to support 2017 better we also updated our Google Android SDK tools. I'm thinking that the switch from dalvik to art has caused us a problem. Since around this time our game is hard crashing at startup on Android. After checking this out for a day it seems from the logs that i2 when updating is having a problem.
Before the long text logs. Going back to older Android build tools is unfortunately not an option for us. Our primary build system is Unity's cloud build, and there are many automated process that cloud build is handling for our projects multiple publishers.
If some one could help me out finding a work around to prevent the device from crashing, and yet still update that would be fantastic. If not I'm thinking we will need to shut down the clients daily update.
08-30 16:08:21.089: A/art(18683): art/runtime/check_jni.cc:65] JNI DETECTED ERROR IN APPLICATION: input is not valid Modified UTF-8: illegal start byte 0xf0
08-30 16:08:21.090: A/art(18683): art/runtime/check_jni.cc:65] string: 'version=1504047418349,script_version=4,[i2category]tutorial[/i2category]Keys[*]Type[*]Description[*]English[*]Chinese (Traditional)[*]Chinese (Simplified)[*]Korean[*]Thai[*]Japanese[*]Malay[*]Vietnamese[*]Indonesian[*]Spanish[*]French[*]German[*]Italian[*]Portuguese[*]Russian[*]Status[ln]opening_screen0[*][*][*]Champions and beasts from all over Terramore brawl in the Grand Arenas to become legends and win the love of the crowd.[*]來自 Terramore 各地的戰士和野獸在大鬥技場互相戰鬥,希望能成為傳奇人物,並贏取觀眾的愛戴。[*]来自 Terramore 各地的战士和野兽在大斗技场互相战斗,希望能成为传奇人物,并赢取观众的爱戴。[*]그랜드 아레나내 테라무어 도처에서 온 챔피온들과 비스트들이 전설이 되고 군중의 환호를 받기 위해 전투합니다.[*]แชมป์และปีศาจจากทั่วทั้งเทอร์รามอร์ต่อสู้กั
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] เศษแก้วสีรงค์: ทำลายคริสตัลศูนย์กลางเพื่อรับขวดยาแบบสุ่มที่ทรงพลัง![*]強力なランダムバフを得るためにクリスタルを破壊します![*]Memusnahkan Crystal untuk mendapatkan seorang penggemar rawak berkuasa![*]Mảnh vỡ: Phá hủy một Tinh thể để nhận được một miếng đai mạnh bất kì[*]Beling: hancurkan Kristal untuk mendapatkan buff acak yang hebat![*]¡Destruye el Cristal central para ganar un gran Poder aleatorio![*]Détruis le Cristal pour acquérir un buff puissant![*]Zerstöre den Kristall, um ein mächtiges Zufallsitem zu erhalten [*]Distruggere il cristallo per ottenere un potente appassionato casuale![*]Destrua o cristal para ganhar um poderoso bonus de batalha aleatório![*]Уничтожьте кристалл, чтобы получить мощный случайный усилитель![*]done[/i2cs
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] Quand actif, Vol de Vie réduit également les dommages entrants[*]Wenn aktiviert, verringert Lebensraub auch den Schaden[*]Quando è attivo, Lifesteal ora riduce anche il danno in arrivo.[*]O Javali toma dano reduzido quando usa a habilidade Roubo de Vida. [*]В то время как активные, Вампиризм теперь также уменьшает входящий урон.[*]In progress[ln]boar_talent_05_desc[*][*][*]Increase Lifesteal duration but decrease its effectiveness.[*]hog talent description [*]增加吸血的持續時間但降低效果。[*]增加吸血的持续时间但降低效果。[*]라이프스틸 지속시간을 증가시키지만 효과는 떨어지게 됩니다.[*]เพิ่มระยะเวลาไลฟ์สตีล แต่ลดประสิทธิภาพ[*]アクティブな間は、ライフスチール持続時間が増えるが、効果を下げる。[*]Meningkatkan tempoh Lifesteal tetapi mengurangkan keberkesanannya.[
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*]Erhöht die Dauer von Lebensraub verringert aber seine Effektivität[*]Aumentare la durata Lifesteal ma diminuisce la sua efficacia.[*]Aumenta a duração do Roubo de Vida, mas reduz sua potência.[*]Увеличение продолжительности Вампиризм, но снизить его эффективность.[*]In progress[ln]boar_talent_06_desc[*][*][*]Marginally increase the effectiveness of Lifesteal.[*]hog talent description [*]少量增加吸血效果。[*]少量增加吸血效果。[*]아주 미미하게 라이프스틸의 효과를 증가시킵니다.[*]เพิ่มประสิทธิภาพของไลฟ์สตีลอย่างมีขอบเขต[*]ライフスチールの効果が少しだけ上げる。[*]Secara marginal meningkatkan keberkesanan Lifesteal.[*]Tăng từ từ hiệu quả của lifesteal[*]Meningkatkan kefektifan Lifesteal.[*]Incrementa marginalmente la efectividad del Robo de Vida.[*]Augment de façon marg
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] Mendapat ekstra kecepatan setelah memakai charge.[*]Gana velocidad extra luego de usar la embestida.[*]Gagne vitesse supplémentaire après avoir utilisé Charge.[*]Gewinne Schnelligkeit nach Charge[*]Guadagnare velocità in più dopo l'utilizzo di carica.[*]Ganha Velocidade de Movimento depois de usar a Investida Esmagadora.[*]Получить дополнительную скорость после использования Charge.[*]In progress[ln]spider_talent_01[*][*][*]Pressurized spit [*]Spider talent name[*]加壓唾沫[*]加压唾沫[*]압축된 침[*]น้ำลายอัดแรงดัน[*]Pressurized spit [*]Ludahan bertekanan[*]Pressurized spit [*]Pressurized spit [*]Escupitajo presurizado[*]Crache Pressurisé[*]Spucke unter Druck[*]spiedo pressurizzato[*]Cuspe Pressurizado[*]Герметичная коса[*]In progress[ln]spider_talent_02[*][*][*]Poison spray[*]Spider talent name[*]藥水噴霧[*]药水喷雾[*]독약 스프레이[*]สเปรย์ยา
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*]Netze halten weniger lang, können aber öfter genutzt werden[*]Webs durano per un breve tempo, ma possono essere utilizzati più spesso.[*]Teias duram menos, mas podem ser usadas mais fequentemente.[*]Полотна длиться более короткий период времени, но можно использовать чаще.[*]In progress[ln]spider_talent_05_desc[*][*][*]Poison now slow opponents.[*]Spider talent description [*]減慢敵人速度的藥水。[*]减慢敌人速度的药水。[*]독약은 이제 적을 느리게 합니다.[*]ยาพิษตอนนี้ทำให้ฝ่ายตรงข้ามช้าลง[*]今、毒が敵を遅くする。[*]Racun kini melambatkan musuh.[*]Đầu độc các đối thủ chậm rãi[*]Racun sekarang membuat musuh lambat.[*]El Veneno ahora ralenta a los oponentes.[*]Poison maintenant ralentis ennemis.[*]Gift verlangsamt jetzt Gegner[*]Veleno avversari ora lenti.[*]O veneno da Aranha reduz a Velocidade
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*][*]Diventa invulnerabili per un breve momento dopo l'utilizzo di Bolt Strike.[*][*]Стать неуязвимым на короткое время после использования Bolt Strike.[*][ln]horse_talent_05_desc[*][*][*]A second Bolt hits the Bolt Strike area after a brief delay.[*][*][*][*][*][*][*][*][*][*][*]Un deuxième Éclair frappe la zone du Coup d'Éclair après un bref délai.[*][*]Un secondo Bolt colpisce l'area Sciopero Bolt dopo un breve ritardo.[*][*]Второй болт попадет в области Удара Болта после короткой задержки.[*][ln]horse_talent_06_desc[*][*][*]Reduce Bolt Strike cooldown to 1 second but remove all damage from the ability[*][*][*][*][*][*][*][*][*][*][*]Réduisez le refroidissement du Coup d'Éclair à 1 seconde, mais enlevez tous les dégâts de la Compétence.
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*][*]Ridurre Bolt Sciopero cooldown a 1 secondo, ma rimuovere tutti i danni dalla capacità[*][*]Уменьшить Удар кулдаун Болта на 1 секунду, но удалить все повреждения от способности[*][ln]scorpion_talent_01[*][*][*]Exoskeleton[*][*][*][*][*][*][*][*][*][*][*]Exosquelette[*][*]exoskeleton[*][*]Экзоскелет[*][ln]scorpion_talent_02[*][*][*]Strong Clamps[*][*][*][*][*][*][*][*][*][*][*]Pinces Fortes[*][*]Morsetti forti[*][*]Сильные Хомуты[*][ln]scorpion_talent_03[*][*][*]Long tail[*][*][*][*][*][*][*][*][*][*][*]Longue Queue[*][*]Coda lunga[*][*]Длинный хвост[*][ln]scorpion_talent_04[*][*][*]Deadly needle[*][*][*][*][*][*][*][*][*][*][*]Aiguille Mortelle[*][*]Deadly ago[*][*]Смертельная игла[*][ln]scorpion_talent_05[*][*][*]Surprise![*][*][*][*][*][*][*][*][*][*][*]Surprise![*][*]Sorpresa![*][*]Сюрприз![*][ln]scorpion_talent_06[*][*][*]Deep Tunnels[*][*][*][*
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*][*]Aumentare danni Sting attacco, ma ridurre la sua area attiva.[*][*]Увеличение урона атаки Стинга, но уменьшить его удар области.[*][ln]scorpion_talent_05_desc[*][*][*]Increase attack speed for 1 second after unborrowing[*][*][*][*][*][*][*][*][*][*][*]Augmenter la vitesse d'attaque pendant 1 seconde après l'emprunt[*][*]Aumentare la velocità di attacco per 1 secondo dopo unborrowing[*][*]Увеличение скорости атаки на 1 секунду после того, как unborrowing[*][ln]scorpion_talent_06_desc[*][*][*]Become harder to detect when burrowed but reduce movement speed.[*][*][*][*][*][*][*][*][*][*][*]Devenir plus difficile à détecter lorsqu'il est creusé mais réduit la vitesse de déplacement.[*][*]Diventa più difficile da rilevare quando scavato, ma ridurre la velocità di movimento.[*][*]Стать труднее обнаружить, когда рыли, но снизить скоро�
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] [*][*]Aumentare la durata della Lava creato da firewall.[*][*]Увеличение продолжительности Лавы, созданный брандмауэре.[*][ln]dragon_talent_06_desc[*][*][*]Decrease Firewall cooldown but reduce Lava duration.[*][*][*][*][*][*][*][*][*][*][*]Diminuez le coiffage du Pare-Feu, mais réduisez la durée de la lave.[*][*]Diminuire Firewall cooldown ma ridurre la durata Lava.[*][*]Уменьшение брандмауэра кулдаун, но сократить продолжительность Лава.[*][ln]phoenix_talent_01[*][*][*]Heat Up[*][*][*][*][*][*][*][*][*][*][*]Chauffer[*][*]Riscaldare[*][*]Разогреть[*][ln]phoenix_talent_02[*][*][*]Fire to Ashes[*][*][*][*][*][*][*][*][*][*][*]Le Feu aux Cendres[*][*]Fuoco to Ashes[*][*]Пожар в Ashes[*][ln]phoenix_talent_03[*][*][*]Supernova[*][*][*][*][*][*][*][*][*][*][*]Supernova[*][*]Supernova[*][*]сверхновая звезда[*][ln]phoenix_talent_04[*][*][*]Fire
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] 明亮的光[*]
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] 明亮的光[*]브라이트 라이트[*]แสงจ้า[*]明るい光[*]Cahaya Cerah[*]Bright Light[*]Bright Light[*]Luz Encandilante[*]Lumière Brillante[*]Strahlendes Licht[*]Luce luminosa[*]Luzes Brilhantes[*]Яркий свет[*][ln]phoenix_03[*][*][*]Royal Bloodline[*]Phoenix skin name[*]皇家血脈[*]皇家血脉[*]로얄 블러드라인[*]สันตติวงศ์[*]ロイヤル・ブラッドライン[*]Garis Darah Diraja[*]Royal Bloodline[*]Royal Bloodline[*]Linaje Real[*]Lignée Royale[*]Königliche Blutlinie[*]Reale Bloodline[*]Linhajem Real[*]Royal Bloodline[*][/i2csv][i2category]skins[/i2category]Keys[*]Type[*]Description[*]English[*]Description[*]Chinese (Traditional)[*]Chinese (Simplified)[*]Korean[*]Thai[*]Japanese[*]Malay[*]Vietnamese[*]Indonesian[*]Spanish[*]French[*]German[*]Italian[*]Portuguese[*]Russian[*]Status[ln]skin_title[*][*][*]Skins[*]page title[*]皮膚[*]皮肤[*]스킨[*]สกิน[*]スキン[*]Kulit[*]Áo[*]Skin[*]Aspectos[*]Ensemble[
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] 綠寶石之龍[*]
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] 绿宝石之龙[*]에머랄드 드래곤[*]มังกรสีมรกต[*]エメラルド・ドラゴン[*]Naga Zamrud[*]Emerald Dragon[*]Emerald Dragon[*]Dragón Esmeralda[*]Dragon Émeraude[*]Smaragddrache[*]Emerald Drago[*][*]Emerald Dragon[*][ln]dragon_03[*][*][*]Ruby Magma[*]Dragon skin name[*]紅寶石岩漿[*]红宝石岩浆[*]루비 마그마[*]หินหนืดสีทับทิม[*]ルビー・マグマ[*]Magma Delima[*]Ruby Magma[*]Ruby Magma[*]Magma Rubí[*]Magma Rubis[*]Magma Rubin[*]rubino Magma[*]Rubi Magma[*]Рубин Magma[*][ln]dragon_02[*][*][*]Sapphire Ice[*]Dragon skin name[*]藍寶石之冰[*] [*]사파이어 아이스[*]น้ำแข็งไพลิน[*]サファイヤ・アイス[*]Ais Nilam[*]Sapphire Ice[*]Sapphire Ice[*]Safiro del Hielo[*]Glace Saphir[*]Eis Saphir[*]Ice Sapphire[*]Safira Gelo[*]Sapphire Ice[*][ln]dragon_05[*][*][*]Topaz Seraph[*]Dragon skin name[*]黃晶撒拉弗[*]黄晶撒拉弗[*]토파즈 세라스[*]เซร�
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] 明亮的光[*]브라이트 라이트[*]แสงจ้า[*]明るい光[*]Cahaya Cerah[*]Bright Light[*]Bright Light[*]Luz Encandilante[*]Lumière Brillante[*]Strahlendes Licht[*]Luce luminosa[*]Luzes Brilhantes[*]Яркий свет[*][ln]phoenix_03[*][*][*]Royal Bloodline[*]Phoenix skin name[*]皇家血脈[*]皇家血脉[*]로얄 블러드라인[*]สันตติวงศ์[*]ロイヤル・ブラッドライン[*]Garis Darah Diraja[*]Royal Bloodline[*]Royal Bloodline[*]Linaje Real[*]Lignée Royale[*]Königliche Blutlinie[*]Reale Bloodline[*]Linhajem Real[*]Royal Bloodline[*][ln]phoenix_4[*][*][*]Quetzal Queen[*]Phoenix skin name[*]克薩爾女皇[*]克萨尔女皇[*]케트살 퀸[*]ราชินีเคว็ตซัล[*]ケツァールの女王[*]Ratu Quetzal[*]Quetzal Queen[*]Quetzal Queen[*]Reina Quetzal [*]Reine Quetzal[*]Quetzal Königin[*]Quetzal regina[*]Rainha Quetzal[*]Кецаль Queen[*][ln]phoenix_06[*][*][*]Wings of Freedom[*]Phoenix skin name[*]自由
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] Mise à jour disponible. Vous pouvez vous connecter à WiFi avant de télécharger.[*]Update verfügbar. Du solltest dein W-Lan für den Download einschalten.[*]Aggiornamento disponibile. Si consiglia di collegarsi a una rete WiFi prima di scaricare.[*][*]Доступно обновление. Вы можете подключиться к Wi-Fi перед загрузкой.[*][ln]download_bundles[*][*][*]Download[*]Download button[*]下載[*]下载[*]다운로드[*]ดาวน์โหลด[*]ダウンロード[*]Muat turun[*]Tải về[*]Unduh[*]Descargar[*]Télécharger[*]Download[*]Scaricare[*][*]Скачать[*][ln]download_bundles_error[*][*][*]Download Error. Restarting.[*]Message for failed to download assets at the splash screen[*]下載錯誤。重新啟動中。[*]下载错误。重新启动中。[*]다운로드 오류. 재시작중.[*]มีข้อผิดพลาดในการดาวน์โหลด เริ่มใหม่[*]ダウンロードエ�
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] in call to NewStringUTF
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] from boolean com.unity3d.player.UnityPlayer.nativeRender()
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] "UnityMain" prio=5 tid=13 Runnable
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] | group="main" sCount=0 dsCount=0 obj=0x12c059e0 self=0xb8be37d0
08-30 16:08:21.091: A/art(18683): art/runtime/check_jni.cc:65] | sysTid=18709 nice=0 cgrp=default sched=0/0 handle=0xb8be3d68
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] | state=R schedstat=( 0 0 0 ) utm=1983 stm=466 core=1 HZ=100
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] | stack=0xb3dfa000-0xb3dfc000 stackSize=1036KB
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] | held mutexes= "mutator lock"(shared held)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #00 pc 00004e64 /system/lib/libbacktrace_libc++.so (UnwindCurrent::Unwind(unsigned int, ucontext*)+23)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #01 pc 00003665 /system/lib/libbacktrace_libc++.so (Backtrace::Unwind(unsigned int, ucontext*)+
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #02 pc 00256401 /system/lib/libart.so (art::DumpNativeStack(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, int, char const*, art::mirror::ArtMethod*)+84)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #03 pc 00238fbf /system/lib/libart.so (art::Thread::Dump(std::__1::basic_ostream<char, std::__1::char_traits<char> >&) const+158)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #04 pc 000b199b /system/lib/libart.so (art::JniAbort(char const*, char const*)+610)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #05 pc 000b20d5 /system/lib/libart.so (art::JniAbortF(char const*, char const*, ...)+68)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #06 pc 000b468f /system/lib/libart.so (art::ScopedCheck::Check(bool, char const*, ...) (.constprop.129)+922)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #07 pc 000be1bd /system/lib/libart.so (art::CheckJNI::NewStringUTF(_JNIEnv*, char const*)+44)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] native: #08 pc 00b741a4 /data/app/io.v2g.beastbrawlers-1/lib/arm/libunity.so (???)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at com.unity3d.player.UnityPlayer.nativeRender(Native method)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at com.unity3d.player.UnityPlayer.c(unavailable:-1)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at com.unity3d.player.UnityPlayer$c$1.handleMessage(unavailable:-1)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at android.os.Handler.dispatchMessage(Handler.java:98)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at android.os.Looper.loop(Looper.java:135)
08-30 16:08:21.092: A/art(18683): art/runtime/check_jni.cc:65] at com.unity3d.player.UnityPlayer$c.run(unavailable:-1)
08-30 16:08:26.735: D/ThermalDaemon(196): Sensor 'tsens_tz_sensor1' - alarm cleared 1 at 54.0 degC
08-30 16:08:26.737: D/ThermalDaemon(196): Sensor 'tsens_tz_sensor2' - alarm cleared 1 at 52.0 degC
08-30 16:08:26.738: D/ThermalDaemon(196): Sensor 'tsens_tz_sensor8' - alarm cleared 1 at 52.0 degC
08-30 16:08:26.739: D/ThermalDaemon(196): Sensor 'tsens_tz_sensor7' - alarm cleared 1 at 54.0 degC
08-30 16:08:27.287: E/WifiStateMachine(565): setScanResults obtaining null BSSID results <00:00:00:00:00:00>, discard it
08-30 16:08:27.716: E/WifiConfigStore(565): rewrite network history for "V2G-Core-EXT"WPA_PSK
08-30 16:08:27.719: E/WifiConfigStore(565): writeKnownNetworkHistory write linked 1
08-30 16:08:27.731: E/WifiConfigStore(565): writeKnownNetworkHistory write linked 1
08-30 16:08:32.080: A/libc(18683): Fatal signal 11 (SIGSEGV), code 2, fault addr 0x74756d4f in tid 18709 (main)
08-30 16:08:32.080: I/libc(18683): Suppressing debuggerd output because prctl(PR_GET_DUMPABLE)==0
08-30 16:08:32.141: I/WindowState(565): WIN DEATH: Window{1d4eb32a u0 io.v2g.beastbrawlers/com.unity3d.player.UnityPlayerActivity}
08-30 16:08:32.142: W/WindowManager(565): Force-removing child win Window{257ed6b8 u0 SurfaceView} from container Window{1d4eb32a u0 io.v2g.beastbrawlers/com.unity3d.player.UnityPlayerActivity}
08-30 16:08:32.192: W/WindowManager(565): Failed looking up window
08-30 16:08:32.192: W/WindowManager(565): java.lang.IllegalArgumentException: Requested window android.os.BinderProxy@3195451b does not exist
08-30 16:08:32.192: W/WindowManager(565): at com.android.server.wm.WindowManagerService.windowForClientLocked(WindowManagerService.java:8539)
08-30 16:08:32.192: W/WindowManager(565): at com.android.server.wm.WindowManagerService.windowForClientLocked(WindowManagerService.java:8530)
08-30 16:08:32.192: W/WindowManager(565): at com.android.server.wm.WindowState$DeathRecipient.binderDied(WindowState.java:1142)
08-30 16:08:32.192: W/WindowManager(565): at android.os.BinderProxy.sendDeathNotice(Binder.java:551)
08-30 16:08:32.192: I/WindowState(565): WIN DEATH: null
08-30 16:08:32.193: I/Zygote(199): Process 18683 exited due to signal (11)
08-30 16:08:32.232: I/ActivityManager(565): Process io.v2g.beastbrawlers (pid 18683) has died
08-30 16:08:32.235: W/ActivityManager(565): Force removing ActivityRecord{176e5696 u0 io.v2g.beastbrawlers/com.unity3d.player.UnityPlayerActivity t18539}: app died, no saved state
08-30 16:08:32.255: V/ActivityManager(565): Display changed displayId=0
9 years 2 months ago #2432
Replied by Frank on topic Hard Crash JNI DETECTED ERROR IN APPLICATION
I'm sorry for the delay in answering back. I have been trying to reproduce any crash in the Google Live Sync code, but haven't been able.
Said that, in the latest betas I have heavily modified this code to save the downloaded data in an obfuscated string. Part of those changes may have fixed the issue you are experiencing.
Could you try v2.8.0b5 and see if the crash is still there?
9 years 2 weeks ago #2529
by JasonV2G
Replied by JasonV2G on topic Hard Crash JNI DETECTED ERROR IN APPLICATION
Thanks, we did find the problem. It is not directly an I2 problem. What we found is that certain Android 4.x version running on the ART runtime will crash with Emojis. During the download that I2 does there is processing on the string and the app crashes do to emoji. For now we have removed emoji's until we have the time to work in a fix.
Time to create page: 0.156 seconds
