Text formatting
- jscott1972
9 years 3 months ago - 9 years 3 months ago #2308
by jscott1972
Text formatting was created by jscott1972
we have lots of text in our game and lots of formatting using \n and \n\n. In the localised text this formatting doesn't work.
Any ideas?
Any ideas?
Last edit: 9 years 3 months ago by jscott1972.
9 years 3 months ago #2313
Replied by Frank on topic Text formatting
The plugin doesn't convert \n into real newlines.
If you specify \n in your translation, then you will get a '\' and a 'n' characters.
To create new lines, you need to make real new lines by pressing 'enter':
9 years 3 months ago #2314
Said that, if you can't change your text to use real newlines, you could set a callback to your localize components and in there, replace "\\n" by '\n".
inter-illusion.com/assets/I2LocalizationManual/Callbacks.html
That will do the trick!
9 years 2 weeks ago #2471
by bennett
Replied by bennett on topic Text formatting
Hey Frank - I have real newlines in my text, but when I go to export to a csv, it breaks each line into a new field (and all the columns get broken). Is there a workaround for this?
9 years 2 weeks ago #2476
Where are you generating the csv file? With I2 Localization or with another program?
I'm exporting csv files with term having multiple lines and the resulting csv is correct (i.e. it has quotes surrounding the multi-line translations)
This explains a bit more:
inter-illusion.com/forum/i2-localization...le-in-v2-8-0-b6#2475
If you are generating the csv file from I2 Localization and its exported wrong, could you please, email me the I2Languages.prefab so that I can try it for myself and see why its failing?
If you generate the csv from an external spreadsheet program (e.g. Excel), please check the exporter settings so that it generates quotes around those lines.
Time to create page: 0.157 seconds
