Bulk Auto-Translation
12 years 3 months ago #186
by Jos
Bulk Auto-Translation was created by Jos
Was wondering if there is a way to trigger the translation for all keys in a language, rather then having to individually click the translate button? Even if this was an API-only thing, i could wire something up to do this.
Use case: We want to test with a language to get an idea of the size of the translated text, even if it isn't the "real" translations we will have done later on.
Jos
Jos
12 years 3 months ago #187
by Jos
Replied by Jos on topic Bulk Auto-Translation
I see that I2.GoogleTranslation has the method i want Translate(), but it is an editor class. Which just means that i need to write an editor script. Now i need a way to iterate though all the keys...
12 years 3 months ago #188
Replied by Frank on topic Bulk Auto-Translation
One way should be to export all the terms into a google spreadsheet and use the language functions to do the translation.
The other is to add a code like this into UpgradeManager.cs
I haven't test that code, but it should take the selected source, and translate from the first language into "Spanish".
You can change that language name at the top of the function.
Hope that helps. And I see that could be handy, so I will add that feature into the source editor. So that after the terms list there could be buttons to auto translate all the empty cells or just the selected languages.
[MenuItem("Tools/I2 Localization/Translate All", false, 0)]
public static void TranslateAll()
string TargetLanguage = "Spanish";
if (!LocalizationEditorDB.HasLanguageSource(true))
Debug.Log("Can't find source");
return;
LanguageSource Source = LocalizationEditorDB.mLanguageSource;
int LanguageIndex = Source.GetLanguageIndex(TargetLanguage);
if (LanguageIndex<0)
Debug.Log("Can't find language in source");
return;
for (int i = 0, imax = Source.mTerms.Count; i < imax; ++i)
TermData data = Source.mTerms[i];
data.Languages[LanguageIndex] = GoogleTranslation.Translate(data.Languages[0], Source.mLanguages[0].Code, Source.mLanguages[LanguageIndex].Code);
}I haven't test that code, but it should take the selected source, and translate from the first language into "Spanish".
12 years 3 months ago #189
by Jos
Ha, I missed your reply while writing this EditorWindow code:
I'll take your less hard-coded bits and integrate with this one. I'm translating ~1200 terms, so i didn't want something that would lock the editor up.
Thanks for the super fast turn-around on that reply!
Please also feel free to take any of this code if it is useful for you.
Jos
using UnityEngine;
using UnityEditor;
using System.Collections;
public class AutoTranslate : EditorWindow {
[MenuItem("Window/Bulk Translate")]
public static void Main()
EditorWindow.GetWindow( typeof( AutoTranslate ) );
private bool _translating = false;
private int index = 0;
private int termsTotal = 0;
private I2.Loc.TermData term;
private string trans = "";
void OnGUI()
if(_translating)
DoTranslatingGUI();
else
if(GUILayout.Button("German"))
index = 0;
termsTotal = I2.Loc.LocalizationEditorDB.mLanguageSource.mTerms.Count;
_translating = true;
void DoTranslatingGUI()
GUILayout.Label("Translating Term: " + index + " of " + termsTotal);
GUILayout.Label("-- " + trans);
if(GUILayout.Button("Cancel"))
void Update()
if(index >= termsTotal && _translating)
Repaint ();
else
term = I2.Loc.LocalizationEditorDB.mLanguageSource.mTerms[index];
trans = I2.GoogleTranslation.Translate(term.Languages[0], "en", "de");
term.Languages[2] = trans;
//Debug.Log("-- " + term.Term + "//" + term.Languages[0] + "//" + trans);
index++;
Repaint();
}I'll take your less hard-coded bits and integrate with this one. I'm translating ~1200 terms, so i didn't want something that would lock the editor up.
Jos
12 years 3 months ago #190
by Jos
Here is a slightly nicer version, with a checkbox for over-writing existing values. Also less hard-coded numbers.
using UnityEngine;
using UnityEditor;
private int langIndex = 0;
private string[] langCodes = new string[]{"en", "fr", "de", "it", "es"};
private string[] langNames = new string[]{"English", "French", "German", "Italian", "Spanish"};
private bool overwriteExisting = false;
void OnGUI()
if(_translating)
DoTranslatingGUI();
else
for(int i = 1; i < 5 ; i++)
if(GUILayout.Button(langNames[i]))
langIndex = i;
index = 0;
overwriteExisting = GUILayout.Toggle(overwriteExisting, "Overwrite Existing Translations");
void Update()
Repaint ();
else if(_translating)
if(string.IsNullOrEmpty(term.Languages[langIndex]) || overwriteExisting)
trans = I2.GoogleTranslation.Translate(term.Languages[0], "en", langCodes[langIndex]);
term.Languages[langIndex] = trans;
index++;
Repaint();
}Please Log in or Create an account to join the conversation.
4 years 11 months ago #4612
by aloskjfna
Replied by aloskjfna on topic Bulk Auto-Translation
This forum has some stuff that talks about Bulk Auto-Translation so in case you think it is good enough and has some stuff that we will like to let others know then that would be a great help for those who need it for some reason at this year. I liked
pendrago reviews
now.
Time to create page: 0.165 seconds
