when project compile , i got an error in unity
9 years 5 months ago #2275
by Emrekhan
when project compile , i got an error in unity was created by Emrekhan
I did all installation like the tutorial. However, When the project compiles in unity, I got below error. What's wrong? Could you help me?
I also try example scenes, the result is same.
StackOverflowException
UnityEngine.GameObject.GetComponent[LanguageSource] () (at /Users/builduser/buildslave/unity/build/artifacts/generated/common/runtime/GameObjectBindings.gen.cs:38)
I2.Loc.LocalizationManager.RegisterSourceInResources () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:597)
I2.Loc.LocalizationManager.UpdateSources () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:568)
I2.Loc.LocalizationManager.InitializeIfNeeded () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:107)
I2.Loc.LocalizationManager.set_CurrentLanguage (System.String value) (at Assets/I2/Localization/Scripts/LocalizationManager.cs:21)
I2.Loc.LocalizationManager.SelectStartupLanguage () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:177)
I2.Loc.LocalizationManager.InitializeIfNeeded () (at Assets/I2/Localization/Scripts/LocalizationManager.cs:108)
Thank you.
Thank you.
9 years 5 months ago #2276
Replied by Frank on topic when project compile , i got an error in unity
In this thread you can find what happened to 2.6.12f2 and how to fix it:
www.inter-illusion.com/forum/i2-localiza...urrent-language#2270
The following user(s) said Thank You: Emrekhan
Time to create page: 0.118 seconds
