Clashing with Firebase Unity plugin
- SweatyChair
Topic Author
- Junior Member
- We made innovative mobile games.
9 years 5 months ago - 9 years 5 months ago #2264
by SweatyChair
Always remember you're unique, just like everyone else.
Clashing with Firebase Unity plugin was created by SweatyChair
Firebase Unity plugin produces a lot of errors even before building, after debugging I found that it's actually because it's not compatible with I2Localiation!
Error:
Basically I think it tries to use UnityEditor.iOS.Xcode.PlistDocument, and somehow getting your modified UnityEditor.iOS_I2Loc.Xcode.PlistDocument.
Both plugins are referencing to dll so nothing I can do, but changing all your UnityEditor.iOS_I2Loc.Xcode refences to UnityEditor.iOS.Xcode and comment project.AddLocalization, plus need to manually do the localization strings in XCode...
I understand that it can be their problem getting the wrong class, but is there anything you think you can do? E.g. Rename PlistDocument, or remove PlistDocument from UnityEditor.iOS_I2Loc.Xcode and use UnityEditor.iOS.Xcode.PlistDocument instead?
Error:
TypeLoadException: Could not load type 'UnityEditor.iOS.Xcode.PlistDocument' from assembly 'Unity.iOS.Extensions.Xcode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'.
Firebase.Editor.XcodeProjectPatcher.ReadConfig (Boolean errorOnNoConfig, System.String filename)
Rethrow as TypeInitializationException: An exception was thrown by the type initializer for Firebase.Editor.XcodeProjectPatcherBasically I think it tries to use UnityEditor.iOS.Xcode.PlistDocument, and somehow getting your modified UnityEditor.iOS_I2Loc.Xcode.PlistDocument.
Last edit: 9 years 5 months ago by SweatyChair.
The following user(s) said Thank You: Kurius
9 years 5 months ago #2265
Replied by Frank on topic Clashing with Firebase Unity plugin
I just changed the dll signature to avoid clashing with the one in Firebase.
Attached you can find the new dll.
could you try replacing the on in Assets\I2\Localization\Scripts\Editor\Unity XCode\
with the one attached here.
Please, let me know if that solves your issue!
- SweatyChair
Topic Author
- Junior Member
9 years 5 months ago #2266
by SweatyChair
Replied by SweatyChair on topic Clashing with Firebase Unity plugin
Thanks for the bolt reply, it fixed and the XCode localized string are output as correctly!
Finally I can see my Unity console with all red errors~
Time to create page: 0.141 seconds
