Translation in editor ok but after build not
9 years 5 months ago - 9 years 5 months ago #2246
by bromske
[img]www.bombnet.de/bombzone/sig/?sigid=6460b2feddc62a52831686f05c81da2a311b0fa5&ply=PACUS&col=red
Translation in editor ok but after build not was created by bromske
I've bought I2Localization and it works fine. I've added a lot of translations for text and comboboxes - in editor mode everything is ok
i can added some buttons to switch the languages und it works too.
But after build, i can't change the language i can see only the first (main) language and the comboboxes with text are empty?!?!
No Errors in log...
Unity 5.6.0p3 + I2L V2.6.11f1 + Windows build
Did i forgot something?
sorry for my bad english
Marco
No Errors in log...
Marco
Last edit: 9 years 5 months ago by bromske.
9 years 5 months ago #2247
Replied by Frank on topic Translation in editor ok but after build not
That sounds like a setup problem.
Its all your terms/languages in the I2Languages.prefab? Or do you have any other LanguageSource?
If you created a duplicate of I2Languages, the plugin will not load it while is in the game (only in the editor, if you already selected that source).
Also, the I2Languages.prefab shouldn't be added to your scene. I2 Localization will load it automatically from the Resources folder.
Another possibility: The build you created doesn't have the correct Script defines. For instance, if you are using TextMesh Pro, remember that you need to add "TextMeshPro" to your build defines. Maybe the defines are correct for one platform, but not for the one you are building now?
Hope that helps, and if you still have this issue, it will help a lot if you could email me some screenshots of your unity editor and build settings. That will help me figure out any miss-setup and give you more detailed advice.
9 years 5 months ago #2255
by bromske
Replied by bromske on topic Translation in editor ok but after build not
Thanks for help,
i've removed the I2 folder and i've reimported it, now it works....
