PostProcessAndroid - "../" not supported in mac
9 years 4 months ago - 9 years 4 months ago #2242 by SweatyChair
When I build Android in iOS and has the game name localized, error appears in PostProcess as:
System.IO.DirectoryNotFoundException: Could not find a part of the path "/Users/fur/Projects/NoHumanityMain/Assets/StreamingAssets/../../Temp/StagingArea/res/values"
  at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x00064] in /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/Directory.cs:131
  at System.IO.Directory.CreateDirectory (System.String path) [0x0009a] in /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.IO/Directory.cs:96
  at I2.Loc.PostProcessBuild_Android.SetStringsFile (System.String folder, System.String fileName, System.String stringXML, System.String appName) [0x0000e] in /Users/fur/Projects/NoHumanityMain/Assets/I2/Localization/Scripts/Editor/PostProcessBuild_ANDROID.cs:77
It seems that double ../ is not supprted in mac?
In this case I simply need to add following line above PostProcessBuild_ANDROID.cs:77:
folder = folder.Replace("Assets/StreamingAssets/../../", "");
Always remember you're unique, just like everyone else.
Last edit: 9 years 4 months ago by SweatyChair.
9 years 4 months ago #2245 by Frank
Good to know. I normally build Android in Windows!
Will double check this and add a fix.
Thanks!!
