UpgradeManager issue with Unity 5.6
9 years 7 months ago - 9 years 7 months ago #2183 by mcmorry
After upgrading to Unity 5.6, the UpgradeManager is throwing this exception:
PlayerSettings Validation: Requested build target group (27) doesn't exist; #define symbols for scripting won't be added.
UnityEditor.PlayerSettings:SetScriptingDefineSymbolsForGroup(BuildTargetGroup, String)
I2.Loc.UpgradeManager:EnablePluginsOnPlatform(BuildTargetGroup) (at Assets/Plugins/I2/Localization/Scripts/Editor/UpgradeManager.cs:112)
I2.Loc.UpgradeManager:EnablePlugins(Boolean) (at Assets/Plugins/I2/Localization/Scripts/Editor/UpgradeManager.cs:83)
I2.Loc.UpgradeManager:CheckPlugins(Boolean) (at Assets/Plugins/I2/Localization/Scripts/Editor/UpgradeManager.cs:32)
I2.Loc.UpgradeManager:AutoCheckPlugins() (at Assets/Plugins/I2/Localization/Scripts/Editor/UpgradeManager.cs:21)
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()
I'm not sure what to do or check to fix it.
Last edit: 9 years 7 months ago by mcmorry.
9 years 7 months ago #2184 by mcmorry
So 27 is the Switch platform.
If I open the Unity build popup, Switch is not listed there.
But the same doesn't apply to other targets that are not listed and are not rising any errors.
9 years 7 months ago #2185 by Frank
I'm releasing a proper fix in the next beta, but for now, a workaround is to skip that platform:
In the file Assets\I2\Localization\Scripts\Editor\UpgradeManager.cs line 81, add the condition target != BuildTargetGroup.Switch
like this:
			foreach (BuildTargetGroup target in System.Enum.GetValues(typeof(BuildTargetGroup)))
				if (target!=BuildTargetGroup.Unknown && !target.HasAttributeOfType<System.ObsoleteAttribute>() && target != BuildTargetGroup.Switch)
					EnablePluginsOnPlatform( target );
The following user(s) said Thank You: mcmorry
