2.6.11a5 - CommandInvokationFailure
9 years 4 months ago #2122
by JOY
2.6.11a5 - CommandInvokationFailure was created by JOY
I got this error in the latest beta version 2.6.11a5. It seems conflict with Unity IAP?
CommandInvokationFailure: Failed to re-package resources.
D:\Android\sdk\build-tools\25.0.1\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res"
stderr[
AndroidManifest.xml:68: error: Error: No resource found that matches the given name (at 'value' with value '@string/fb_app_id').
AndroidManifest.xml:71: error: Error: No resource found that matches the given name (at 'value' with value '@integer/google_play_services_version').
AndroidManifest.xml:72: error: Error: No resource found that matches the given name (at 'value' with value '@string/gg_key').
stdout[
Configurations:
(default)
vi
en
en-rUS
Files:
values\strings.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values\strings.xml
Src: (vi) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-vi\strings.xml
Src: (en) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-en\strings.xml
Src: (en-rUS) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-en-rUS\strings.xml
AndroidManifest.xml
Src: () AndroidManifest.xml
Resource Dirs:
Type values
values\strings.xml
Including resources from package: D:\Android\sdk\platforms\android-25\android.jar
applyFileOverlay for drawable
applyFileOverlay for layout
applyFileOverlay for anim
applyFileOverlay for animator
applyFileOverlay for interpolator
applyFileOverlay for transition
applyFileOverlay for xml
applyFileOverlay for raw
applyFileOverlay for color
applyFileOverlay for menu
applyFileOverlay for mipmap
Processing image: res\drawable-xhdpi\app_banner.png
Processing image: res\drawable-ldpi\app_icon.png
Processing image: res\drawable-mdpi\app_icon.png
Processing image: res\drawable-hdpi\app_icon.png
(processed image res\drawable-ldpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xhdpi\app_icon.png
(processed image res\drawable-mdpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xxhdpi\app_icon.png
(processed image res\drawable-hdpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xxxhdpi\app_icon.png
(processed image res\drawable-xhdpi\app_icon.png: 99% size of source)
(processed image res\drawable-xhdpi\app_banner.png: 93% size of source)
(processed image res\drawable-xxhdpi\app_icon.png: 99% size of source)
(processed image res\drawable-xxxhdpi\app_icon.png: 98% size of source)
(new resource id app_banner from xhdpi-v4\drawable\app_banner.png #generated)
(new resource id app_icon from ldpi-v4\drawable\app_icon.png #generated)
(new resource id app_icon from mdpi-v4\drawable\app_icon.png #generated)
(new resource id app_icon from hdpi-v4\drawable\app_icon.png #generated)
(new resource id app_icon from xhdpi-v4\drawable\app_icon.png #generated)
(new resource id app_icon from xxhdpi-v4\drawable\app_icon.png #generated)
(new resource id app_icon from xxxhdpi-v4\drawable\app_icon.png #generated)
exit code: 1
UnityEditor.Android.Command.Run (System.Diagnostics.ProcessStartInfo psi, UnityEditor.Android.WaitingForProcessToExit waitingForProcessToExit, System.String errorMsg)
UnityEditor.Android.PostProcessor.Tasks.TasksCommon.Exec (System.String command, System.String args, System.String workingdir, System.String errorMsg, Int32 retriesOnFailure)
UnityEditor.HostView:OnGUI()
9 years 4 months ago #2123
Replied by Frank on topic 2.6.11a5 - CommandInvokationFailure
I think I know what the issue is. As soon as I get back home I will make a fix for it and upload the new beta.
Thanks for reporting this!
9 years 4 months ago #2124
by JOY
Replied by JOY on topic 2.6.11a5 - CommandInvokationFailure
Thank you. I'm looking for it.
9 years 4 months ago #2125
I uploaded v2.6.11 b1 to the beta folder. That includes a change that fixes that problem.
Could you try it and let me know if it works properly now in your project?
9 years 4 months ago #2126
by JOY
D:\Android\sdk\build-tools\25.0.2\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization:com.vtcmobile.gamesdk -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res"
stderr[
stdout[
Configurations:
(default)
v11
v14
mdpi-v4
hdpi-v4
xhdpi-v4
xxhdpi-v4
xxxhdpi-v4
sw360dp-v13
vi
Files:
anim\enter.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\enter.xml
anim\exit.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\exit.xml
anim\pop_enter.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\pop_enter.xml
anim\pop_exit.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\pop_exit.xml
anim\slide_in_right.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_in_right.xml
anim\slide_out_left.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_out_left.xml
anim\slide_out_right.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_out_right.xml
color\vpi__dark_theme.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__dark_theme.xml
color\vpi__dialog_theme.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__dialog_theme.xml
color\vpi__light_theme.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__light_theme.xml
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_box.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_right.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_btn_sms_left.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_sms_left.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_btn_sms_left.9.png
Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_btn_sms_left.9.png
Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_btn_sms_left.9.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_btn_sms_right_focus.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_sms_right_focus.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_btn_sms_right_focus.9.png
Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_btn_sms_right_focus.9.png
Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_btn_sms_right_focus.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_divider.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_fg_pw.png
drawable\bg_main_layout.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable\bg_main_layout.xml
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_middle.png
Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_mysoha_notification.9.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_payment.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_scoin_chat.9.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_sms_right.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_sms_right.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_sms_right.9.png
Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_sms_right.9.png
Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_sms_right.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_spinner.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_trans_time.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_tv_quest.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_tv_quest.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_tv_quest.9.png
Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_tv_quest.9.png
Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_tv_quest.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_tv_sms.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_update.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_user_chat.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bkg_avatar.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\black_trans_bg.png
drawable\bot_border_gray.xml
Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable\bot_border_gray.xml
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_add_image.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_add_issue.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_back_focused.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_back_normal.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_blue121.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_blue_clicked.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_blue_normal.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_close_focused.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_close_normal.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_fb_normal.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_gg_hor_focus.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_gg_hor_normal.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_gg_normal.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_disabled.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_disabled.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_focus.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_focus.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_normal.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_normal.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_pressed.9.png
Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_pressed.9.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_green.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_item_left.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_item_right.9.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focus1.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focused.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focused1.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_normal.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_normal1.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_fb.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_gg.png
Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_vtcid.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_middle_focus1.png
Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\<message truncated>Please Log in or Create an account to join the conversation.
9 years 4 months ago #2127
by JOY
Event after I delete ScoinGameSDK_Lib:
D:\Android\sdk\build-tools\25.0.2\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res"
stderr[
stdout[
Configurations:
(default)
vi
en
en-rUS
Files:
values\strings.xml
AndroidManifest.xml
Resource Dirs:
Type values
values\strings.xml
exit code: 1
UnityEditor.HostView:OnGUI()Please Log in or Create an account to join the conversation.
Time to create page: 0.193 seconds
