2.6.11a5 - CommandInvokationFailure
9 years 5 months ago #2122 by JOY
I got this error in the latest beta version 2.6.11a5. It seems conflict with Unity IAP?
CommandInvokationFailure: Failed to re-package resources.
D:\Android\sdk\build-tools\25.0.1\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res"
stderr[
AndroidManifest.xml:68: error: Error: No resource found that matches the given name (at 'value' with value '@string/fb_app_id').
AndroidManifest.xml:71: error: Error: No resource found that matches the given name (at 'value' with value '@integer/google_play_services_version').
AndroidManifest.xml:72: error: Error: No resource found that matches the given name (at 'value' with value '@string/gg_key').
stdout[
Configurations:
 (default)
 vi
 en
 en-rUS
Files:
  values\strings.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values\strings.xml
    Src: (vi) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-vi\strings.xml
    Src: (en) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-en\strings.xml
    Src: (en-rUS) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res\values-en-rUS\strings.xml
  AndroidManifest.xml
    Src: () AndroidManifest.xml
Resource Dirs:
  Type values
    values\strings.xml
Including resources from package: D:\Android\sdk\platforms\android-25\android.jar
applyFileOverlay for drawable
applyFileOverlay for layout
applyFileOverlay for anim
applyFileOverlay for animator
applyFileOverlay for interpolator
applyFileOverlay for transition
applyFileOverlay for xml
applyFileOverlay for raw
applyFileOverlay for color
applyFileOverlay for menu
applyFileOverlay for mipmap
Processing image: res\drawable-xhdpi\app_banner.png
Processing image: res\drawable-ldpi\app_icon.png
Processing image: res\drawable-mdpi\app_icon.png
Processing image: res\drawable-hdpi\app_icon.png
    (processed image res\drawable-ldpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xhdpi\app_icon.png
    (processed image res\drawable-mdpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xxhdpi\app_icon.png
    (processed image res\drawable-hdpi\app_icon.png: 99% size of source)
Processing image: res\drawable-xxxhdpi\app_icon.png
    (processed image res\drawable-xhdpi\app_icon.png: 99% size of source)
    (processed image res\drawable-xhdpi\app_banner.png: 93% size of source)
    (processed image res\drawable-xxhdpi\app_icon.png: 99% size of source)
    (processed image res\drawable-xxxhdpi\app_icon.png: 98% size of source)
    (new resource id app_banner from xhdpi-v4\drawable\app_banner.png #generated)
    (new resource id app_icon from ldpi-v4\drawable\app_icon.png #generated)
    (new resource id app_icon from mdpi-v4\drawable\app_icon.png #generated)
    (new resource id app_icon from hdpi-v4\drawable\app_icon.png #generated)
    (new resource id app_icon from xhdpi-v4\drawable\app_icon.png #generated)
    (new resource id app_icon from xxhdpi-v4\drawable\app_icon.png #generated)
    (new resource id app_icon from xxxhdpi-v4\drawable\app_icon.png #generated)
exit code: 1
UnityEditor.Android.Command.Run (System.Diagnostics.ProcessStartInfo psi, UnityEditor.Android.WaitingForProcessToExit waitingForProcessToExit, System.String errorMsg)
UnityEditor.Android.PostProcessor.Tasks.TasksCommon.Exec (System.String command, System.String args, System.String workingdir, System.String errorMsg, Int32 retriesOnFailure)
UnityEditor.HostView:OnGUI()
9 years 5 months ago #2123 by Frank
I think I know what the issue is. As soon as I get back home I will make a fix for it and upload the new beta.
Thanks for reporting this!
9 years 5 months ago #2124 by JOY
Thank you. I'm looking for it.
9 years 5 months ago #2125 by Frank
I uploaded v2.6.11 b1 to the beta folder. That includes a change that fixes that problem.
Could you try it and let me know if it works properly now in your project?
9 years 5 months ago #2126 by JOY
D:\Android\sdk\build-tools\25.0.2\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization:com.vtcmobile.gamesdk -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res"
stderr[
stdout[
Configurations:
 (default)
 v11
 v14
 mdpi-v4
 hdpi-v4
 xhdpi-v4
 xxhdpi-v4
 xxxhdpi-v4
 sw360dp-v13
 vi
Files:
  anim\enter.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\enter.xml
  anim\exit.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\exit.xml
  anim\pop_enter.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\pop_enter.xml
  anim\pop_exit.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\pop_exit.xml
  anim\slide_in_right.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_in_right.xml
  anim\slide_out_left.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_out_left.xml
  anim\slide_out_right.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\anim\slide_out_right.xml
  color\vpi__dark_theme.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__dark_theme.xml
  color\vpi__dialog_theme.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__dialog_theme.xml
  color\vpi__light_theme.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\color\vpi__light_theme.xml
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_box.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_right.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_btn_sms_left.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_sms_left.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_btn_sms_left.9.png
    Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_btn_sms_left.9.png
    Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_btn_sms_left.9.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_btn_sms_right_focus.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_btn_sms_right_focus.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_btn_sms_right_focus.9.png
    Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_btn_sms_right_focus.9.png
    Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_btn_sms_right_focus.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_divider.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_fg_pw.png
  drawable\bg_main_layout.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable\bg_main_layout.xml
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_middle.png
    Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_mysoha_notification.9.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_payment.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_scoin_chat.9.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_sms_right.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_sms_right.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_sms_right.9.png
    Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_sms_right.9.png
    Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_sms_right.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_spinner.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_trans_time.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_tv_quest.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_tv_quest.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_tv_quest.9.png
    Src: (xxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxhdpi-v4\bg_tv_quest.9.png
    Src: (xxxhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xxxhdpi-v4\bg_tv_quest.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bg_tv_sms.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\bg_update.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\bg_user_chat.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\bkg_avatar.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\black_trans_bg.png
  drawable\bot_border_gray.xml
    Src: () F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable\bot_border_gray.xml
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_add_image.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_add_issue.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_back_focused.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_back_normal.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_blue121.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_blue_clicked.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_blue_normal.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_close_focused.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_close_normal.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_fb_normal.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_gg_hor_focus.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_gg_hor_normal.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_gg_normal.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_disabled.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_disabled.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_focus.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_focus.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_normal.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_normal.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_google_signin_light_pressed.9.png
    Src: (xhdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-xhdpi-v4\btn_google_signin_light_pressed.9.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_green.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_item_left.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_item_right.9.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focus1.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focused.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_focused1.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_normal.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_left_normal1.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_fb.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_gg.png
    Src: (mdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-mdpi-v4\btn_login_vtcid.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\ScoinGameSDK_Lib\res\drawable-hdpi-v4\btn_middle_focus1.png
    Src: (hdpi-v4) F:\Dropbox (JOY Entertainment)\Projects\<message truncated>
9 years 5 months ago #2127 by JOY
Event after I delete ScoinGameSDK_Lib:
D:\Android\sdk\build-tools\25.0.2\aapt.exe package --auto-add-overlay -v -f -m -J "gen" -M "AndroidManifest.xml" -S "res" -I "D:/Android/sdk\platforms\android-25\android.jar" -F bin/resources.ap_ --extra-packages com.unity.purchasing:com.android.vending.billing:com.unity.purchasing.googleplay:com.InterIllusion.I2Localization -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\common\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GoogleAIDL\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\GooglePlay\res" -S "F:\Dropbox (JOY Entertainment)\Projects\BulletStrike\Temp\StagingArea\android-libraries\I2Localization\res"
stderr[
stdout[
Configurations:
 (default)
 vi
 en
 en-rUS
Files:
  values\strings.xml
  AndroidManifest.xml
Resource Dirs:
  Type values
    values\strings.xml
exit code: 1
Time to create page: 0.172 seconds
