Dynamically assign translation?
12 years 4 months ago #158 by aholla
Hi I was wondering how I would access the Translation in code? I have a list of fields and wan to to be able to look up the terms based upon an id or a string or something.
Adam
12 years 4 months ago #159 by Frank
You can translate any term (ID) by using
string Translation = ScriptLocalization.Get( Term )
If what you want its changing the localization to attach numbers or other things, Like transforming
"THE SCORE IS {SCORE}" into "THE SCORE IS 320"
Then you can use the localization callbacks. There is an example on the "UnityStandards Localization" scene
More details at: www.inter-illusion.com/forum/i2-localiza...irectly-from-scripts
If you want to execute your scripts everytime the language is changed, use the LocalizationManager.OnLocalizeEvent
www.inter-illusion.com/forum/i2-localiza...-call-without-target
The following user(s) said Thank You: aholla
Time to create page: 0.161 seconds
