playmaker
9 years 8 months ago #2084 by elusiven
playmaker was created by elusiven
Hi, I've seen on trello that playmaker support has been added. I cannot see the actions though - are they downloadable from somewhere?
9 years 8 months ago #2086 by Frank
Replied by Frank on topic playmaker
Sorry for the delay in answering, I was at GDC at the internet was really bad there!
If you download the version 2.6.10b6 or better: 2.6.10f1 from the beta folder, inside the Assets\I2\Localization there is unitypackage. If you install that package, then it will add all the new PlayMaker actions!
9 years 8 months ago - 9 years 8 months ago #2088 by elusiven
Replied by elusiven on topic playmaker
Thanks for reply.. I do not have any unity packages files in Assets/I2/Localization. Can't find any links either.
Where do you download beta versions?
Also, if I set a key at run-time to something else, because my data is dynamic so I need to be able to set different keys at run-time so it can grab different translated data from google but, will the key automatically update after I set it, or do I need to call a method to do that?
Last edit: 9 years 8 months ago by elusiven.
9 years 8 months ago #2089 by Frank
This file is only available in the beta version. I also uploaded v2.6.10f1 to the AssetStore, but it hasn't been approved yet.
inter-illusion.com/forum/i2-localization...ssing-early-versions
To change the term at runtime you need to call the method SetTerm of the Localize component:
inter-illusion.com/assets/I2Localization...geLocalizeTerms.html
That will change the term, and automatically update the text of the label's to the term's translation. It will also update the text every time the language changes.
In PlayMaker, there is also an action that allows changing the term.
9 years 8 months ago - 9 years 8 months ago #2090 by elusiven
Ah okay... I sent you my invoice.. Could you please give me access to the latest versions?
Also what's the performance of set term, is it quite resource hungry or not too much?
9 years 8 months ago #2091 by Frank
Done, you should have received an email with the invite.
SetTerm just changes the term, gets the translation for that term and applies it, it doesn't do much things.
Said that, in previous versions, there was a call to free the unused unity resources, that call was heavily impacting performance if there were many loaded resources. But in the latest version, I changed the way that works, so SetTerm is pretty light and shouldn't impact the performance!
Time to create page: 0.163 seconds
