Using I2 Localization as a database.
9 years 9 months ago - 9 years 9 months ago #1982
by robo99
Using I2 Localization as a database. was created by robo99
Is it possible to get the amount of TERMS for a given category?
I'm make a name generator where I want the names to be localized.
Last edit: 9 years 9 months ago by robo99.
9 years 9 months ago - 9 years 9 months ago #1985
Replied by Frank on topic Using I2 Localization as a database.
You can get the list of ALL terms using
Also, you can find what category a term has by using
And to get a list of all terms in a category, you can either iterate and add to a list, or for short using Linq:
string[] terms = LocalizationManager.GetTermsList();Also, you can find what category a term has by using
string category = LanguageSource.GetCategoryFromFullTerm( Term );And to get a list of all terms in a category, you can either iterate and add to a list, or for short using Linq:
using System.Linq;
string Category = "example";
string[] terms = LocalizationManager.GetTermsList().Where(x => (LanguageSource.GetCategoryFromFullTerm(x) == Category)).ToArray();Hope that helps,
Last edit: 9 years 9 months ago by Frank.
The following user(s) said Thank You: robo99
9 years 9 months ago #1997
by robo99
Replied by robo99 on topic Using I2 Localization as a database.
Thanks, Frank!
7 years 10 months ago #3394
by robo99
I just updated and "LanguageSource.GetCategoryFromFullTerm()" is now gone... What to do?
7 years 10 months ago #3395
Because of the recent changes to the Unity Prefabs, all the functionality of the LanguageSource moved into LanguageSourceData
So, you should use:
So, you should use:
LanguageSourceData.GetCategoryFromFullTerm(...)Hope that helps,
Time to create page: 0.170 seconds
