TextMeshPro text vertical text
9 years 11 months ago #1924
by alan2110
TextMeshPro text vertical text was created by alan2110
I haven't upgraded in a while so maybe something you have fixed.
Now and then I will have a TextMeshPro object that has a Localize component and things look fine in the Editor but when I run the text displays completely vertical stacked one character at a time. Then the next time it refreshes it fixes itself.
Sometimes I can get it to go away if I mess with the TextMeshPro inspector values, like disabling wordwrap or changing the text rectangle. But it seems to randomly occur to other TextMeshPro items as we change things in development. And I don't want to have to keep trying to fix it whenever it appears.
I traced it down to the function DoLocalize_TMPUGUILabel(), mTarget_TMPUGUILabel.ForceMeshUpdate() call. If I comment this out then the problem seems to go away. But I don't want that to be my solution as I am scared that might be a needed call. I don't use RTL alignment so is it needed?
9 years 11 months ago #1926
Replied by Frank on topic TextMeshPro text vertical text
Can I ask you what version of I2 Localization are you using?
That seems like the error related to SetText. Previously the plugin set the text but wasn't using the right TextMeshPro function, so its layout/size wasn't been updated.
As always, my advise is for you to update to the latest version (2.6.9b1) as there are lots of fixes and improvements that make the plugin far more stable.
If you can't update because you are about to release your game/app, but have a workaround that works all the time for you, then that's the safest you can do. Nonetheless, the best is to update as soon as possible to avoid finding any of the other issues that are already fixed.
9 years 11 months ago #1932
by alan2110
Replied by alan2110 on topic TextMeshPro text vertical text
version I have is 2.6.1 f2
it's been working pretty well for us and our project went live recently so I haven't had a real reason to update until now. I just need to find a good time in our schedule to do it.
Is there something I could band-aid on the SetText call for now until I fully update?
9 years 11 months ago #1934
by alan2110
never mind, I'm looking into updating to the latest now. I'll let you know if that fixes things. thanks!
9 years 11 months ago #1935
by alan2110
upgrading has fixed this problem. thanks!
9 years 11 months ago #1936
Great!!
There has been several changes to the TextMeshPro integration, I'm glad those fixed your issue!
Time to create page: 0.174 seconds
