Crash after importing in my project
9 years 11 months ago - 9 years 11 months ago #1908 by shark812
Just bought that asset but can't use cause after importing, my Unity 5.4.3f1 (64 bit on Windows 10) crashes, and it still continue after reopening.
Need some help,
thanks
UPDATE - It was a problem with the 2 fonts inside the package (Arial and comics), after deselecting them from the import i was able to make it work. I will write down the stacktrace to help you fixing the issue:
========== OUTPUTING STACK TRACE ==================
0x000000014136F69E (Unity) TrueTypeFontImporter::LookupFallbackFontReferences
0x0000000141372123 (Unity) TrueTypeFontImporter::GenerateFont
0x0000000141373933 (Unity) TrueTypeFontImporter::GenerateAssetData
0x00000001406C9581 (Unity) AssetDatabase::ImportAsset
0x00000001406D885F (Unity) AssetDatabase::UpdateAsset
0x000000014077DE84 (Unity) AssetInterface::ProcessAssetsImplementation
0x000000014077EBA8 (Unity) AssetInterface::StopAssetEditing
0x0000000140785235 (Unity) AssetInterface::Refresh
0x0000000140C683B9 (Unity) ImportPackageAssets
0x0000000140C6F3AF (Unity) TickPackageImport
0x0000000140BE35B8 (Unity) Application::TickTimer
0x0000000140E47E2E (Unity) FindMonoBinaryToUse
0x0000000140E49461 (Unity) WinMain
0x00000001415AD460 (Unity) strnlen
0x00007FFA3A608364 (KERNEL32) BaseThreadInitThunk
========== END OF STACKTRACE ===========
Tell me if you need more infos
Last edit: 9 years 11 months ago by shark812.
9 years 11 months ago #1909 by Frank
That's a pretty weird issue, unity is crashing reading a font file!
I tried reproducing this, but its not happening for me.
I just downloaded 5.4.3f1 64bits and I have windows 10, however, all my projects import just fine and even if I make a new project and import from the store, it seems to be working as expected with no crashes.
Which makes me think there is something with your project setup or plugins.
- Can I ask you what platform is your unity set to when crashing (IOS, Android, PC, etc?)
- Do you have more versions of those fonts in your project? Maybe other plugins have them.
- Can you email me the list of the plugins (and their versions) that you are using? It could be that one of them is customizing the import and overriding the unity standard importer. I would like to test in a project set as closely to your as possible to see if I can reproduce that crash.
- if you close Unity, delete your Library folder, and then reopen unity so that it re-generates the Library folder, do you still see this crash? For some unity versions, that helps in case there is a corruption somewhere when upgrading your project.
9 years 11 months ago - 9 years 11 months ago #1911 by shark812
- Android
- I searched but didn't find those
- Last version of: EnhancedScroller v2, Darkstone Theme, Fx Quest, PackageUninstaller, OneSignal SDK, Phonon PUN, PlayerPrefs Elite, Rainbow Folders, Sprite Packer, UI Pac: Nightmare
- After removing those fonts, the plugin worked so i didn't try
