Custom materials for tk2d fonts
- vividhelix
9 years 11 months ago #1894
by vividhelix
Custom materials for tk2d fonts was created by vividhelix
I'm trying to change the font per language while using tk2d text meshes.
Unfortunately I'm using a custom shader with additional textures. Just changing the font isn't enough unfortunately.
Are there any workarounds? I see I can define textures as terms, so ideally I'd need to change two of the textures on the material upon also changing the font.
Can you point me in the right direction?
9 years 11 months ago #1896
Replied by Frank on topic Custom materials for tk2d fonts
I2Loc allows changing the font by using the Secondary Terms. When the font is changed, the material and textures associated with that font are also changed to the one that come with the new font.
What you normally would do for you case, is to create a new font and assign a NEW material and textures to it. That way, material and textures will be automatically changed.
Font1 (using Mat1, that references Texture1, Texture2 and several float parameters)
Font2 (using Mat2, that references Texture3, Texture4 and several float parameters)
Secondary Term assigns Font1 or Font2 depending on the language.
However, if your Font2, reuses the same material, then its a problem to handle that.
e.g. Font2 (using Mat1)
Said that, if you really need to make more modifications to how the font/material/textures are handled, you could do it with a callback .
Just pack all the data you need into the SecondaryTerm translation and then parse that data back and apply any custom modification:
e.g. Instead of having the secondary term for English be "MyEnglishFont", make it "MyEnglishFont,MyCustomMaterial,MyTexture1,34"
Then, add this callback script to your localize component:
That way you have full control over what modifications you do based on the language.
class CallbackExample : Monobehaviour // this could be a separated class or a method in one of your own scripts
// if no MainTranslation then skip (most likely this localize component only changes the font)
return;
string[] data = Localize.MainTranslation.Split(",");
string FontName = data[0];
string MaterialName = data[1];
string TextureName = data[2];
float ShaderParameter = float.Parse(data[3]);
tk2dFont newFont = Localize.FindTranslatedObject<tk2dFont>(FontName); // loads the font from the Resources folder
Material newMat = Localize.FindTranslatedObject<Material>(MaterialName); // or if referenced in the Assets section
Texture newTex = Localize.FindTranslatedObject<Texture>(TextureName);
newMat.SetFloat("MyParameter", ShaderParameter);
newMat.SetTexture("MyTexture", newTex);
var textMesh = Localize.GetComponent<tk2dTextMesh>();
textMesh.font = newFont.data;
textMesh.font.material = newMat;
}That way you have full control over what modifications you do based on the language.
Time to create page: 0.120 seconds
