Disable auto localization of scripts
10 years 4 days ago #1886 by maciek
New version of i2 localization automatcly localize also in scripts parsing
for example I'm using double.Parse that need to use ALWAYS en-US cultureinfo. But I2 localize overwriting this, and my double.Parse doesn't work because it use for example "," instead of "."
How to disable this auto localization for scripts?
10 years 3 days ago #1887 by Frank
Last week I released a new alpha with a change that solves the issue.
The problem is that plugin is automatically setting the CurrentCulture based on the language. That setting affects everything that is localizable.
If you download the latest from the beta folder (2.6.9a1) that feature is disabled by default and can be enabled (if you need it by dragging the EnableAutoCultureInfo script into your startup scene)
If you don't want to update to the latest just yet, you could change the function SetLanguageAndCode in LocalizeManager.cs line 108
by this one:
		public static void SetLanguageAndCode( string LanguageName, string LanguageCode, bool RememberLanguage = true, bool Force = false )
			if (mCurrentLanguage != LanguageName || mLanguageCode != LanguageCode || Force)
				if (RememberLanguage)
					PlayerPrefs.SetString ("I2 Language", LanguageName);
				mCurrentLanguage = LanguageName;
				mLanguageCode = LanguageCode;
                                IsRight2Left = IsRTL (mLanguageCode);
                                LocalizeAll(Force);
that disables the cultureInfo setting.
