Having Trouble with Farsi
10 years 2 weeks ago #1865 by sgschris
I have setup I2 Localization in a project but am having trouble with RTL languages, particularly Farsi. Unfortunately, the characters are rendering separately rather than connected.
Here's what I've done:
1) Downloaded the asset and imported everything but the examples folder
2) Imported terms from a semi-colon separated file encoded as UTF-8
3) Setup the localize component on the target game object with a Text components (uGUI)
4) Set a max line length for RTL languages (adjust alignment is also checked)
Upon playing the game, the text is rendered RTL but the letters aren't connected. I have seen some examples of I2 with this working, so I assume I've just missed something. Any suggestions?
On a side note, overall I2 has been great to work with! Very happy other than this one issue.
10 years 2 weeks ago #1867 by Frank
Replied by Frank on topic Having Trouble with Farsi
The plugin will apply an RTL fix If you created an RTL language in the I2Languages.prefab (e.g a Language with one of this codes:{"ar-DZ", "ar","ar-BH","ar-EG","ar-IQ","ar-JO","ar-KW","ar-LB","ar-LY","ar-MA","ar-OM","ar-QA","ar-SA","ar-SY","ar-TN","ar-AE","ar-YE", "he","ur","ji"})
If the LanguageCode of that language is not one of those, then the Arabic Fix is skipped.
Also, Could you send me the text that is giving you issues so that I could test it in here as well? Or send me the I2Languages.prefab, or an example project!
I will check your setup and let you know of anything that I could find.
Time to create page: 0.125 seconds
