Translate is changing the case of my text
10 years 4 weeks ago #1807
by cpotter
Translate is changing the case of my text was created by cpotter
I have been using the webservice to do translations and it had been working well. I just updated recently and now the translator is changing all of the text to lower case when translated. This is a problem because I don't have a simple way to retype the translation in some languages without setting up multiple keyboards with the special characters for each language.
Is there some way you could add an override that allows me to specify i want an all caps translation?
Craig
Craig
10 years 4 weeks ago - 10 years 4 weeks ago #1808
Replied by Frank on topic Translate is changing the case of my text
I just found an issue when the text was ALL in Caps. (Will this be the case you are referring?)
This can be fixed by replacing the function GetTranslationWWW from
Assets\I2\Localization\Scripts\Google\GoogleTranslation.cs
with this one:
I'm going to be uploading today 2.6.8f4 to the beta folder including this fix
with this one:
public static WWW GetTranslationWWW( string text, string LanguageCodeFrom, string LanguageCodeTo )
LanguageCodeFrom = GoogleLanguages.GetGoogleLanguageCode(LanguageCodeFrom);
LanguageCodeTo = GoogleLanguages.GetGoogleLanguageCode(LanguageCodeTo);
// Google has problem translating this "This Is An Example" but not this "this is an example"
// so I'm asking google with the lowercase version and then reverting back
if (TitleCase(text)==text && text.ToUpper()!=text)
text = text.ToLower();
string url = string.Format("{0}?action=Translate&list={1}:{2}={3}", LocalizationManager.GetWebServiceURL(), LanguageCodeFrom, LanguageCodeTo, Uri.EscapeUriString( text ));
//Debug.Log (url);
WWW www = new WWW(url);
return www;
}I'm going to be uploading today 2.6.8f4 to the beta folder including this fix
Last edit: 10 years 4 weeks ago by Frank.
10 years 4 weeks ago #1811
by cpotter
Replied by cpotter on topic Translate is changing the case of my text
Yes I was having trouble with all caps. Thanks for your quick response very appreciated!
Craig
Craig
10 years 4 weeks ago #1812
BTW, I just uploaded version 2.6.8f4 to the beta folder, which includes that fix.
- Mogulbasher
10 years 3 weeks ago #1814
by Mogulbasher
Replied by Mogulbasher on topic Translate is changing the case of my text
I would like to email you to send you the invoice to obtain access to the beta, but I cant find your email address anywhere in your profile. Can you advise please
Many thanks
Many thanks
10 years 3 weeks ago #1815
Instructions to access the beta can be found here: inter-illusion.com/forum/i2-localization...ssing-early-versions
But basically, you just need to send me an email to This email address is being protected from spambots. You need JavaScript enabled to view it. with your unity invoice number and I can grant you access to the beta folder.
Time to create page: 0.172 seconds
