v2.6.8 f2 compiler error
10 years 1 month ago #1803
by paramburu
v2.6.8 f2 compiler error was created by paramburu
Just tried that version and it seems there is a bug with one of the methods:
The problem seems to be that there is a fourth argument now (bool ignoreRTLnumbers) on LocalizationManager.GetTermTranslation and there is no overloaded method with only three. For now I just added to LocalizationManager
Assets/I2/Localization/Scripts/ScriptLocalization.cs(10,127): error CS1501: No overload for method `GetTermTranslation' takes `3' arguments
public static string GetTermTranslation (string Term, bool FixForRTL, int maxLineLengthForRTL) { return GetTermTranslation (Term, FixForRTL, maxLineLengthForRTL, false); }
10 years 1 month ago #1804
Replied by Frank on topic v2.6.8 f2 compiler error
You are correct!
If you already had a ScriptLocalization file generated, then it breaks. It works again as soon as you Re-generate the file (by deleting it and allowing the plugin to automatically re-create it).
I'm adding the fix for that.
You are correct!
