Translate whole Language doesn't work: 400 Bad Req
- ArmadaHenrik
10 years 1 month ago #1765
by ArmadaHenrik
Translate whole Language doesn't work: 400 Bad Req was created by ArmadaHenrik
I added some new languages to our project, but the automatic translation in the Languages tab does not work.
If I click Translate next to Korean for example, I get error:
Breakpointing LocalizationEditor::OnLanguageTranslated gives me a returned error:
"400 Bad Request\r"
The Web Service should be set up correctly, since individual Term translations work in the Terms tab, and clicking Verify next to Web Service URL shows the green tick (also debugging it returned 4 for both required and current versions).
Any idea why automatically translating whole language doesn't work?
I2 version used is 2.6.6 b1 and Unity is 5.4.1f1. I'm running Windows 10. We are a bit cautious about updating i2 so if this could be solved without an update, that would be optimal. Thanks!
Unable to access Google or not valid request
I2.Loc.LocalizationEditor:ShowMessage(String, MessageType, Boolean) (at Assets/Plugins/I2Localization/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:205)
I2.Loc.LocalizationEditor:ShowError(String, Boolean) (at Assets/Plugins/I2Localization/Localization/Scripts/Editor/Localization/LocalizationEditor.cs:190)
I2.Loc.LocalizationEditor:OnLanguageTranslated(String, String) (at Assets/Plugins/I2Localization/Localization/Scripts/Editor/Localization/LocalizationEditor_Languages.cs:273)
I2.Loc.LocalizationEditor:CheckForConnection() (at Assets/Plugins/I2Localization/Localization/Scripts/Editor/Localization/LocalizationEditor_Spreadsheet_Google.cs:479)
UnityEditor.EditorApplication:Internal_CallUpdateFunctions()Breakpointing LocalizationEditor::OnLanguageTranslated gives me a returned error:
"400 Bad Request\r"
10 years 1 month ago #1771
Replied by Frank on topic Translate whole Language doesn't work: 400 Bad Req
Most likely there is an invalid character that is breaking the web request.
It will help me A LOT, if you could send me your I2Languages.prefab so that I could try localizing all and make a fix for whatever is invalidating the URL.
- ArmadaHenrik
10 years 1 month ago #1777
by ArmadaHenrik
Hi Frank and thanks for fast reply. How would I go about sending you the i2Languages.prefab privately?
BTW we had previously used the feature successfully. I'm not sure when it stopped working.
Meanwhile I made a script which translates all the Terms one by one (in the same way you can do in the Terms tab). So our work is not blocked right now but it's an ugly and slow way.
Replied by ArmadaHenrik on topic Translate whole Language doesn't work: 400 Bad Req
Frank wrote: Hi,
10 years 1 month ago - 10 years 1 month ago #1778
You can email it to me: This email address is being protected from spambots. You need JavaScript enabled to view it.
10 years 3 weeks ago - 10 years 3 weeks ago #1817
by oscarken
Replied by oscarken on topic Translate whole Language doesn't work: 400 Bad Req
Seems I have the same problem, do you find any problems?
I found error like this:
413 Request Entity Too Large
the count of mLanguageSource.mTerms is 943
Last edit: 10 years 3 weeks ago by oscarken.
10 years 3 weeks ago #1825
Thanks a lot for sending me the I2Languages.prefab!! I was able to find what's the issue and I'm modifying the plugin to handle those cases. I should have a beta with that fix in the few days, as it involves adjusting a bit how the multiple translations were communicating with the WebService!
I will let you know as soon as its ready to use!
BTW, I also noticed that your I2Languages.prefab is behaving weird and taking a bit longer than expected after every recompile. I'm checking that as well, and will send you both fixes!
The following user(s) said Thank You: ArmadaHenrik
Time to create page: 0.152 seconds
