Have a Mesh with a Material on it
10 years 1 month ago #1759
by alan2110
Have a Mesh with a Material on it was created by alan2110
I have a Mesh Renderer with a Material on it and the Material has a texture that I want to localize.
What would be the best way to do it? I tried adding a localized Material entry and then when I add a Localize component onto my object that has a Mesh Renderer, the Localize component has no target to link to.
10 years 1 month ago #1762
Replied by Frank on topic Have a Mesh with a Material on it
The current version doesn't allow localizing the texture of a material in a MeshRenderer. It can change the textures in UI elements, and the materials but no the MeshRenderer.
Adding new targets is really easy so I will definitively add that in the next release!
In the meantime, a workaround you can use is to add a Localize component to the MeshRenderer (even if the component doesn't show any target, it will execute the callbacks). So, create an script and add the following callback to the localize component.
public class TextureCallback : MonoBehaviour
return;
var mesh = GetComponent<MeshRenderer>();
var loc = GetComponent<I2.Loc.Localize>();
var texture = loc.FindTranslatedObject<Texture>(Localize.MainTranslation);
mesh.material.mainTexture = texture;
}Hope that helps,
10 years 4 weeks ago #1764
by alan2110
Replied by alan2110 on topic Have a Mesh with a Material on it
Thanks, that did the trick!
9 years 1 month ago #2441
by rsodre
Replied by rsodre on topic Have a Mesh with a Material on it
Still cant localize a MeshRenderer?
That's a surprise, i tought it was so trival since we have material terms.
Well, i\I'll have to write some code then.
9 years 1 month ago #2442
You can localize Prefabs, if that's what you are referring.
In the Standard Component Example Scene, there is a mesh that is localized (in one language it shows a Sphere, in other it shows a cube, etc).
9 years 1 month ago #2443
by rsodre
I actually want to localize the material of a mesh renderer.
Would be nice if the Localize script could select the MeshRenderer as target and then select a Material OR Texture term
Time to create page: 0.174 seconds
