Auto set Thread.CurrentThread.CurrentCulture
10 years 2 weeks ago - 10 years 2 weeks ago #1757
by mcmorry
Auto set Thread.CurrentThread.CurrentCulture was created by mcmorry
I have an issue with Turkish language.
C# won't do correct uppercasing until I run this code:
specifically the dotless i (ı) and the i at the end in this text:
Başlangıç Paketi
should become:
BAŞLANGIÇ PAKETİ
Would be possible to execute it automatically when the language is chosen/detected, and also when clicking on the "Show" button in the list of languages?
Thread.CurrentThread.CurrentCulture = new CultureInfo("tr-TR", false);specifically the dotless i (ı) and the i at the end in this text:
Başlangıç Paketi
should become:
BAŞLANGIÇ PAKETİ
Last edit: 10 years 2 weeks ago by mcmorry.
10 years 2 weeks ago #1758
Replied by Frank on topic Auto set Thread.CurrentThread.CurrentCulture
Will add that in the next beta, thanks for the suggestion!
The following user(s) said Thank You: mcmorry
10 years 1 week ago #1767
by mcmorry
Replied by mcmorry on topic Auto set Thread.CurrentThread.CurrentCulture
I installed the new version b7 but I didn't find any reference in the readme.
I wanted to test it but now I have a compilation error in the ScriptLocalization file because GetTermTranslation requires one new params.
I tried to regenerate the file (Toos -> Script -> Build Script with Selected Terms) but didn't change. Is it a bug or I'm doing something wrong? (I didn't select any terms)
A put false as default and compiled, but I still have problem with Turkish language.
10 years 1 week ago #1768
Changing the currentCulture didn't make it into b7. However, if you download 2.6.8b9 it is included!
Yes, when I made b7 I didn't fully tested the scriptLocalization generation.
b9 fixes that!
b9 fixes that!
Time to create page: 0.146 seconds
