Bug in EditorTools - DrawEventCallBack()
12 years 5 months ago #127
by Jos
Bug in EditorTools - DrawEventCallBack() was created by Jos
I'm trying to get the "On Localize Call" bits of the Localize component to work correctly. It seems that the event, when sent, does include a reference to the component itself, however, the DrawEventCallBack() method only lists methods with no arguments, thus you can never actually receive the Localize component via the callback, and programatically actually do something with that text. Also, since the callback is called before the TextMesh's (in my case) .text value is updated, so i can't get the translated text that way either.
Suggestions? Is this an error?
Jos
Jos
12 years 5 months ago - 12 years 5 months ago #128
Replied by Frank on topic Bug in EditorTools - DrawEventCallBack()
Version (2.1.0 b3) fixes the bug regarding methods accepting 1 argument not been selectable in the EventCallBack.
That will allow you to get the Localize component passed as a parameter.
Nonetheless, the Localization Call Back should use temporal translations on the static variables:
In Assets\I2\Localization\Examples\Common\Scripts\CallbackNotification.cs you can find an example on how to modify those values:
When the Localize component is translating a text, it stores the translations in the Localize.MainTranslation and Localize.SecondaryTranslation so that they can be modified by the callback.
Localize.MainTranslation and Localize.SecondaryTranslation;In Assets\I2\Localization\Examples\Common\Scripts\CallbackNotification.cs you can find an example on how to modify those values:
return;
string PlayerColor = LocalizationManager.GetTermTranslation( "Color/Red" );
Localize.MainTranslation = Localize.MainTranslation.Replace("{PLAYER_COLOR}", PlayerColor);
}When the Localize component is translating a text, it stores the translations in the Localize.MainTranslation and Localize.SecondaryTranslation so that they can be modified by the callback.
Last edit: 12 years 5 months ago by Frank.
12 years 5 months ago #129
by Jos
Replied by Jos on topic Bug in EditorTools - DrawEventCallBack()
Ah, ok, great - that will let me move forward!
Jos
Jos
